PIM Sparse-Mode Config
cisco_raj
Hi Friends..
Please find the attachment below...I need to know the configuration commands for the RP (Rendezvous Point) for PIM sparse-mode...My LHR and FHR are not coming in Neighbor state instead they remain in HELLO state...
Would be highly thankful for ur help...
THNX
RAJ
5 Replies 5
you should configure ´ip multicast-routing´ on all 3 routers, then ´ip pim sparse-mode´ on all interfaces, as well as the command ´ip pim rp-address´ on all 3 routers. The RP must obviously be reachable form both routers.
Can you post the configurations of your routers ?
GP
Hi Georg,
The LHR and FHR are emulated routers in IXIA Traffic generator which are configured with all the necessary parameters (unfortunately can't post their configs since it's configured in GUI). The RP is obviosuly reachable from LHR and FHR since this is back to back ethernet connectivity.However I am posting the config for RP as follows :
----------------CONFIGURATION STARTS-----------------
Building configuration...
Current configuration:
version 11.0
service udp-small-servers
service tcp-small-servers
hostname cisco2500
enable secret 5 $1$IOdN$Mn5ENom3p7nmW9Cu.gi4g.
enable password cisco
no ip domain-lookup
ip dvmrp route-limit 7000
interface Ethernet0
ip address 10.1.1.1 255.255.255.0
ip pim sparse-mode
ip igmp join-group 225.1.0.1
ip igmp join-group 225.1.0.2
ip igmp join-group 225.1.0.3
ip igmp join-group 225.1.0.4
interface Ethernet1
ip address 20.1.1.1 255.255.255.0
ip pim sparse-mode
interface Serial0
no ip address
shutdown
interface Serial1
no ip address
ip pim rp-address 10.1.1.1 1
ip pim message-interval 10
access-list 1 permit 225.0.0.0 0.255.255.255
line con 0
line aux 0
transport input all
line vty 0 4
password cisco
login
end
----------------CONFIGURATION ENDS-------------------
THNX
RAJ
Hello Raj,
the configuration looks very much ok. The only thing I can think about is that your 2500 is running PIM version 1, while the IXIA multicats emulator supports version 2. Can you try and configure ´ip pim version 2´ on your 2500 interfaces ?
If that doesn´t help, or if the interfaces are already set to version 2, can you post the output of ´show ip mroute´ from one of the routers LHR or FHR ?
GP
Hi Georg..
As I said the LHR and FHR are emulated routers so I won't be able to post their configs since they have a GUI...But I can u give the following info :
The host on LHR is 10.1.1.3 for which 10.1.1.2 is the tester (IXIA) port for which default gateway is 10.1.1.1 and the multicast source is 225.1.0.1 to 225.1.0.4
The host on FHR is 20.1.1.3 for which 20.1.1.2 is the tester (IXIA) port for which the default gateway is 20.1.1.1
On my FHR the RP is 10.1.1.1
On LHR it's again 10.1.1.1
If I try and do sh ip PIM neighbors, it doesn't show me anything...
I am also pasting the sh ip mroute & sh ip mroute count for RP :
--------------------sh ip mroute---------------------
(*, 225.1.0.1), 00:28:34/never, RP 10.1.1.1, flags: SCL
Incoming interface: Null, RPF nbr 0.0.0.0
Outgoing interface list:
Ethernet1, Forward/Sparse, 00:28:34/0:02:32
Ethernet0, Forward/Sparse, 00:28:34/0:02:28
(*, 225.1.0.2), 00:28:34/never, RP 10.1.1.1, flags: SCL
Ethernet1, Forward/Sparse, 00:28:34/0:02:30
Ethernet0, Forward/Sparse, 00:28:35/0:02:29
(*, 225.1.0.3), 00:28:35/never, RP 10.1.1.1, flags: SCL
Ethernet1, Forward/Sparse, 00:28:34/0:02:24
Ethernet0, Forward/Sparse, 00:28:35/0:02:28
(*, 225.1.0.4), 00:28:36/never, RP 10.1.1.1, flags: SCL
Ethernet1, Forward/Sparse, 00:28:35/0:02:20
Ethernet0, Forward/Sparse, 00:28:36/0:02:29
------------------sh ip mroute count-----------------
IP Multicast Statistics - Group count: 4, Average sources per group: 0.00
Counts: Pkt Count/Pkts per second/Avg Pkt Size/Kilobits per second
Group: 225.1.0.1, Source count: 0, Group pkt count: 0
RP-tree: 0/0/0/0
Group: 225.1.0.2, Source count: 0, Group pkt count: 0
RP-tree: 0/0/0/0
Group: 225.1.0.3, Source count: 0, Group pkt count: 0
RP-tree: 0/0/0/0
Group: 225.1.0.4, Source count: 0, Group pkt count: 0
RP-tree: 0/0/0/0
THNX
RAJ
Hello Raj,
check if the sender application has set the TTL value to 1. Your groups are not joining the SPT, for some reason.
Also, check this document, it has some more troubleshooting techniques:
IP Multicast Troubleshooting Guide
http://www.cisco.com/warp/public/105/mcastguide0.html
GP
