ping different pc from different vlans
gentidisha
I want to ping between pc from different vlans using router on a stick. I can ping pc in the same vlan.
Interface between router and switch appears down.
Thank you
Harold Ritter
Hi @gentidisha ,
It appears to be a Packet Tracer glitch. Try to remove the 1841 and add it back. It should solve the issue of the interface not coming up between the 1841 and the 2950-24.
Also make sure that you change the PC1 and PC3 IP addresses. That are currently in subnet
192.168.1.0/24
and they should be in
192.168.2.0/24
(vlan11).
Harold Ritter
Hi @gentidisha ,
192.168.1.0/24
192.168.2.0/24
(vlan11).
Hi, thank you now it works, now the pc can ping each other.
I changed 1841 with router 2901.
