Ping fails on POS config
kaustav.gupta
Would like to know if Packet over Sonet tested in Lab if so I have a config which is having issues:
In back to back 7206 with NM-OC3-MM I have configured as follows :
with IP address 10.1.1.1 and 10.1.1.2
int pos4/0
ip add 10.1.1.1 255.255.255.252
pos framing sonet
crc 32
pos scramble-atm
pos flag s1s0 0
I checked for Line alarms there are none and if the layer 1/2 is admin shut the other end goes down. But the ping fails..
Any idea
wochanda
Level 4
Level 4
If this is back-to-back, you're going to want 'clock source internal' configured on both sides.
Also, make sure you have 'pos scramble-atm' on the other end.
Everything is same except the IP Address.
Regs
Kas
