ping gets through but phone unable to register?
Ibrahim Jamil
Level 6
Level 6
Hi Folks
I have to sites connected togather using 4 MBps Link over the tunnel terminated on asa 5510,the call manager in site 1  and the other users on the site 2 unable to register with call mamager on site while i have a suceesull ping goes from site 2 to site 1 (call manager ip) so why this phone its not registered ,so in term of network no problems coz the ping gets through and am rely on ping to confirm that no network problem
---what is the problem for that ?
----How i troubleshoot?
----is there any udp traffic problem that prevent the phone registration
20 Replies 20
manish arora
Level 6
Level 6
Hi Ibrahim,
what are you using for signaling protocol ? For example SIP or MGCP etc , you have to enable inspection for this protocols on the ASA.
post sh service-policy from the ASA's
Manish
HI
The signaling protocol is SIP and inspection has been enabled under policy map
but the ping its gets trough,can u expain this?
can u help more?
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sip
  inspect netbios
  inspect tftp
Ok, run packet tracer to see where is the packet being dropped, run it on the far end ASA where the SIP server is. check out the example on how to use packet tracer tool :-
http://www.cisco.com/en/US/products/ps6120/products_tech_note09186a00807c35e7.shtml
Manish
what do u mean by Packets droped? is it ping packet? pings packets goes with any lose?can u help more in term of CLI Debug
Ok , when you will run packet tracer , it gives you various options , like source ip , source port , destination ip dest port and then interface with direction and check for the whole path and tells you why the packet was dropped.
so , do couple of things on the ASA where the sip server is :-
1> sh service-policy inspect sip  ( This will show if the sip packets are being dropped )
2> run packet tracer
a-fw01# packet-tracer input outside udp SOURCE_IP  4263  SIP_SERVER_IP sip
This will tell you where and why the packets are getting dropped.
manish
My Freind,can u explain why the ping packet goes back in forth with no packet lose?
Because it is ICMP , not tcp/udp , if the firewall is allowing ICMP doesnot means that will allow other protocols be it layer 3 or any other upper layer protocols. That is why is have being telling you to run packet tracer and see by your self that why icmp is not being dropped and sip traffic is being dropped.
manish
Thanks for ur reply!
so i will issue command on the asa where the call manager exist?am i right
2nd I wont rely just on ICMP to confirm that evry thing is perfect?pls correct me if  am wrong
---> YES
---> YES , incase of firewall , if icmp work doesn;t mean that its perfect. you could have inspections/rules dropping other packets.
Manish
hi
Pls check the below
asa5510# sh service-policy inspect sip
Global policy:
  Service-policy: global_policy
    Class-map: inspection_default
      Inspect: sip , packet 180, drop 0, reset-drop 0
               tcp-proxy: bytes in buffer 0, bytes dropped 0
So, that looks perfect as inspection isn't dropping anything.
can you please run the packet tracer command  :-
where SOURCE_IP = ip add of the client to the sip server.
and
SIP_SERVER_IP = ip add of the sip server itself.
manish
if the sip inspection is not configure thus we will face packet drop?am i right?
Yes, that is generally the case
Manish
My Freind What this inspection looks lile?
