ping gets through traceroute doesn't
witek77
Hi everyone,
I've got small LAN, two routers 2600 series one and 1700 series one and laptop computer connected to the 2600 one.
Pings both ways get through fine.
C:\Users\witek>ping 192.168.2.1
Pinging 192.168.2.1 with 32 bytes of data:
Reply from 192.168.2.1: bytes=32 time=1ms TTL=254
Ping statistics for 192.168.2.1:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
    Minimum = 1ms, Maximum = 1ms, Average = 1ms
adam2#ping 192.168.1.100
Sending 5, 100-byte ICMP Echos to 192.168.1.100, timeout is 2 seconds:
Success rate is 80 percent (4/5), round-trip min/avg/max = 1/2/4 ms
Tracert command produces traceroute from the laptop via 2600 router to 1700 router just fine but when I try to traceroute from 1700 router through 2600 router to laptop it only gets to 2600 router and then I get the stars.
C:\Users\witek>tracert 192.168.2.1
Tracing route to 192.168.2.1 over a maximum of 30 hops
  1     1 ms     1 ms     1 ms  192.168.1.1
  2     1 ms     1 ms     2 ms  192.168.2.1
Trace complete.
adam2#traceroute 192.168.1.100
Tracing the route to 192.168.1.100
  1 192.168.2.2 0 msec 0 msec 4 msec
  2  *  *  *
  3  *  *  *
and the stars till no. 30
With a help of members of this community(thanks a lot) I discovered that tarceroute on cisco routers sends UDP packets and I did another inbound rule for incoming UDP packets allowing them on all ports (before I had to do one for ICMP Echo Request to be able to allow pings). I even turn the windows firewall completely off but so far had no luck with getting the traceroute command through to laptop. Here is a startup-config on 2600 router, maybe that will help?
bartek#show startup-config
Using 1137 out of 29688 bytes
version 12.2
service password-encryption
hostname bartek
enable secret 5 $1$e3y1$mP5ucOkByHS6hutqhD.BA/
enable password 7 0316541E120A331E
ip subnet-zero
interface Ethernet0/0
description siec lokalna 192.168.1.0
no ip mroute-cache
half-duplex
no mop enabled
interface BRI0/0
no ip address
no ip mroute-cache
shutdown
interface Serial0/0
no ip address
no ip mroute-cache
shutdown
no fair-queue
interface Ethernet0/1
description SIEC LOKALNA 192.168.2.0
ip address 192.168.2.2 255.255.255.0
no ip mroute-cache
half-duplex
ip classless
ip http server
banner exec ^C
JESTEM BANNER exec POJAWIAM SIE PRZED LOGOWANIEM DO TRYBU UPRZYWILEJOWANEGO ^C
banner login ^C
WITAM JESTEM BANNER login I POJAWIAM SIE PO motd LECZ PRZED LOGOWANIEM ^C
banner motd ^C
Uwaga!!!
Logujsz sie na router. Wszystkie czynnosci sa rejestrowane. ^C
line con 0
exec-timeout 60 0
password 7 01120205563405002F
logging synchronous
login
line aux 0
line vty 0 4
password 7 111B16100317195F
login
end
Any ideas why doesn't traceroute get through greatly appreciated.
Hello
Sounds you have an access list being applied , if so need to make sure both icmp/udp is being allowed, in fact i would rewove all ACL's and test again, if that work you know its as a result of your acl, Also suggest you make all interfaces FULL DUPLEX
Kind Regards
Paul
