Ping issue
Hi Netpros,
It looks to me a very strange behavior, I cannot ping from my Router to the Servers/Workstations, but I can ping vice-versa. What could cause such a problem??
Thanks in advance for queries.
andysaykao
I had a similar problem to this once.
Topology: Internet <- Cisco 827 <- Laptop (using /29)
Laptop could not ping the Cisco 827, but the Cisco 827 could ping the Laptop.
I did a quick fix by changing the Laptop's IP address to use another IP address in the /29 range and then the Laptop was able to ping the Cisco 827.
I didn't investigate further sorry...
23 Replies 23
ankurbhasin
Level 9
Level 9
Hi faizm,
Is this router serving as a gateway for your servers/workstations?
Any ACLs implemented on router for icmp?
Any firewalls implemented on workstation?
Ankur
Hi Ankur,
Thanks for a quick relpy. The Router is infact the Gateway for the Servers/Workstations. But the Router does not have any ACL's and no Firewall in between only a 2900 Switch with a flat configuration.
Hi Faizm,
When you try to ping any workstation from router can you check if the arp entry is build up on the router or is it like incomplete arp entry?
Did it started happening all of sudden?
Ankur
Kevin Dorrell
Level 10
Level 10
Very often if you can ping in one direction but not the other, then it is a question of the source address of the ping. For example, when the PCs ping the router, they ping to one of the router's addresses. When the router pings the PCs, it is pinging from a source address that is different to the one that the PC is using.
Try using an extended ping to make sure the router is pinging from the address that the PCs are successfully pinging to. If that works, then try and work out which address the router is pinging from by default.
Kevin Dorrell
Luxembourg
When I do a extended ping it is pinging from serial interface as the source to the LAN, but when I ping from FastEthernet as the source to the LAN it is not. And the ip's which I am trying to ping are displayed in the ARP table.
What are the factors associated with this kind of behavior?
Hi Faizm,
Thats a strange behavior. If possible can you paste the output of "sh run"
Ankur
Hi Ankur,
Please take a look at the sh run output.
can you pls check the routes configured in the PC or server correctly because this will create a problem , you can check it by using "route print " command in case of a windows machine
Usually, if you ping an address from a router, the router uses the source address of the interface out of which it is performing the ping.
What if the interface has more than one IP address? Someone correct me if I am wrong, but I think it uses the primary address of the interface. Again, someone correct me if I am wrong, but I think it does that even if it has a secondary addresses in the same subnet as the target.
Other complications exist if you have two routes to the target, each out a different interface, and you are running per packet load balancing.
Kevin Dorrell
Luxembourg
Kevin is quite correct. The default behavior of the Cisco router is to use as source address for ping the address of the interface out of which it will send the ping packet. If the interface is configured with a secondary address it will use as source address the primary address, even if the target is in the subnet of the secondary address.
We have an option to over-ride this default behavior in extended ping where we have an option to specify the source address for the ping packet and can choose any other address from any other interface on the router.
Rick
Rick
Hi Kevin/Rick,
But the "sh run" posted by the original poster does not have any secondary address configured on his lan interface so what else can be the reason of the symptom which he is facing?
Ankur
Ankur
You are correct that the config as posted does not have secondary addresses.
While I believe that Kevin's comment is correct that sometimes when traffic will flow in one direction but not in the other, that it is a problem with routing I do not believe that is the issue here.
I believe that you asked a key question in your first post:
and the original poster misunderstood and responded that there was no firewall "between" the end station and the router.
And I believe that you asked another good troubleshooting question when you asked if the MAC address showed up in the ARP table. The original poster responded that they do show up in the ARP table.
This leads me to guess that your first question may lead to the problem. I am guessing that there is a firewall implemented ON the workstation that is not alowing ping to the workstation.
Rick
Rick
Rick,
There is no client firewall on any worksations or server. As I mentioned before in the post that I am able to ping succesfully to any Server/Workstation if I use an extended ping. If there was any client firewall on any Workstation or Server then the Router should not extended ping as well, right.
Thanks for the helpful replies guys.
Regards.
