PING ISSUE**************
singh.ashish
I have ASA and router in my nw. The problem is some times i unable to ping the asa outside int ip from router which is on same subnet. As i reboot my asa and pix problem get resolved. Even i check arp table and all, everthing seems to be fine. What could be problem
ivillegas
Level 6
Level 6
Try manually setting the speed and duplex setting on PIX to 100 mbps , full. Check for any loose cable connections.
