Ping problem?
aefstathiou41
In packet tracer my wireless laptop can ping other PC's in the network but PC's cannot ping the laptop.
This is the IP of laptop (192.168.200.100) and I am pinging from the PC.
C:\>ping 192.168.200.100
Pinging 192.168.200.100 with 32 bytes of data:
Reply from 20.1.1.1: Destination host unreachable.
Ping statistics for 192.168.200.100:
    Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
Here I am pinging from laptop the PC.
ping 20.1.1.10
Pinging 20.1.1.10 with 32 bytes of data:
Reply from 20.1.1.10: bytes=32 time=32ms TTL=124
Reply from 20.1.1.10: bytes=32 time=11ms TTL=124
Reply from 20.1.1.10: bytes=32 time=18ms TTL=124
Reply from 20.1.1.10: bytes=32 time=27ms TTL=124
Ping statistics for 20.1.1.10:
  Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
  Minimum = 11ms, Maximum = 32ms, Average = 22ms
18 Replies 18
post the Packet Tracer project file (rename the .pkt to .jpg otherwise you cannot upload)...
When I rename it it shows me that
<The contents of the attachment doesn't match its file type.>
Are you renaming the file in Explorer ?
Yes
What does your topology look like ? Post the configs of the devices you have in your network...
At the first post I have post the topology in jpg file
R2#sh run
Building configuration...
Current configuration : 918 bytes
version 15.1
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname R2
no ip cef
no ipv6 cef
license udi pid CISCO1941/K9 sn FTX1524A08J
spanning-tree mode pvst
interface GigabitEthernet0/0
no ip address
duplex auto
speed auto
shutdown
interface GigabitEthernet0/1
ip address 20.1.1.1 255.255.255.0
duplex auto
speed auto
interface Serial0/0/0
ip address 192.168.10.1 255.255.255.252
interface Serial0/0/1
no ip address
clock rate 2000000
shutdown
interface Vlan1
no ip address
shutdown
router ospf 1
router-id 2.2.2.2
log-adjacency-changes
passive-interface GigabitEthernet0/1
network 192.168.10.0 0.0.0.3 area 0
network 20.1.1.0 0.0.0.255 area 0
ip classless
ip flow-export version 9
line con 0
line aux 0
line vty 0 4
login
end
R1#sh run
Current configuration : 971 bytes
version 15.1
hostname R1
no ip cef
no ipv6 cef
license udi pid CISCO1941/K9 sn FTX152440EW
no ip address
duplex auto
speed auto
shutdown
ip address 10.1.1.1 255.255.255.0
duplex auto
speed auto
ip address 192.168.10.2 255.255.255.252
clock rate 4000000
ip address 192.168.20.1 255.255.255.252
interface Vlan1
no ip address
shutdown
router ospf 1
router-id 1.1.1.1
network 192.168.20.0 0.0.0.3 area 0
network 10.1.1.0 0.0.0.255 area 0
ip classless
line con 0
line aux 0
line vty 0 4
login
end
R3#sh run
Current configuration : 944 bytes
version 15.1
hostname R3
no ip cef
no ipv6 cef
license udi pid CISCO1941/K9 sn FTX15249KO1
no ip address
duplex auto
speed auto
shutdown
duplex auto
speed auto
no ip address
clock rate 2000000
shutdown
ip address 192.168.20.2 255.255.255.252
clock rate 4000000
interface Vlan1
no ip address
shutdown
router ospf 1
router-id 3.3.3.3
network 192.168.1.0 0.0.0.255 area 0
ip classless
line con 0
line aux 0
line vty 0 4
login
end
where do you announce or redistribute into OSPF the networks 192.168.100.0/24 and 192.168.200.0/24 ? How is the wireless router connected to your network ?
I think I am not announce them. That could probably be the problem? The wireless router is connected through the switch that is connected on the router (R3). The wireless laptop can ping everything the problem is the vise versa.
on R3, configure two static routes and redistribute them into OSPF:
R3
ip route 192.168.100.0 255.255.255.0 GigabitEthernet0/1
ip route 192.168.200.0 255.255.255.0 GigabitEthernet0/1
router ospf 1
redistribute static
Request timed out.
Request timed out.
Request timed out.
Request timed out.
can you post the output of 'show ip route' from R3 ?
R3(config)#do sh ip route
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
i - IS-IS, L1 - IS-IS level-1, L2 - IS-IS level-2, ia - IS-IS inter area
* - candidate default, U - per-user static route, o - ODR
P - periodic downloaded static route
Gateway of last resort is not set
10.0.0.0/24 is subnetted, 1 subnets
O 10.1.1.0/24 [110/65] via 192.168.20.1, 00:56:29, Serial0/0/1
20.0.0.0/24 is subnetted, 1 subnets
O 20.1.1.0/24 [110/129] via 192.168.20.1, 00:56:19, Serial0/0/1
192.168.1.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.168.1.0/24 is directly connected, GigabitEthernet0/1
L 192.168.1.1/32 is directly connected, GigabitEthernet0/1
192.168.10.0/30 is subnetted, 1 subnets
O 192.168.10.0/30 [110/128] via 192.168.20.1, 00:56:29, Serial0/0/1
192.168.20.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.168.20.0/30 is directly connected, Serial0/0/1
L 192.168.20.2/32 is directly connected, Serial0/0/1
S 192.168.100.0/24 is directly connected, GigabitEthernet0/1
S 192.168.200.0/24 is directly connected, GigabitEthernet0/1
Maybe you can use a free file sharing program such as Dropbox to send the file...
