ping problem
cfajardo1_2
scenario:
vlans(Main)--router(Main)--15 branches(frame-relay)
Findings;
1. all of the branches except that of branch 15 are working fine.
2. branch 15 is having 2 vlans (A and B). Vlan A could ping a server in Main whereas a machine in Vlan B will only have a successful reply after more than a minute of pinging. Everything will be fine after the successful ping. This is happenning every morning or after a night long idle.
any idea/help is appreciated.
thanks
hoogen_82
Level 4
Level 4
What switch are you using in the 15th branch? Could you post your config. At the face of it you might have a default gateway configured on your switch. If possible enable ip route and check.
Hoogen
def gateway is there pointing to the router..the switch is a layer 3 3com.
Are you using something similar to a static route pointing to the router or given a default-gateway statement.
Use a static default route. It might help out.
Hoogen
