reg:2600
ramnetindia
Dear sir,
how can i change the flow control on 2600 router
plz reply
srinivas.d
CSCO10892433
Level 4
Level 4
Hi, ramnetindia
Flow control is only available for async interfaces. There are always two ports you can cofigure flowcontrol on the 2600 router: Console port and AUX port. You can configure it as below:
Router(config-line)#flowcontrol [hardware|software|none]
SSLIN
