ping problem
abhi
I am having 4 routers, 2 at each location and 2 catlyst switches 1 at each location. My routers are connected back to back via e1. and also router at each location are connect with the switch. But i am not able to get ping from one network to other
ankbhasi
Hi Abhi,
Can you check with "sh ip route" whether routes are available to ping from one network to other?
Also you are not able to ping 2 different networks attached on same router or across the locations?
Ankur
Hi Ankur,
I have checked "sh ip route" i am seeing the routes for the network.
Hi Ankur,
Please find attached visio file. This is the senario. The router 1 & 2 are old routers. And 3 & 4 are new routers. I am not able to ping from 3 the local network of 2 & 4 and vice versa. And I want only static routes. I have tested it with routing portocol such as RIP it get ping. When I removed one of the e1 link from the router it goes to another way.
Abhijit
