ping response to selected source IP
josephschung
Sir,
For the same destination IP, is it possible to let a router use routeA for ping response and routeB for all other protocol?
For example, destination ip is 192.168.1.100 and have the two routes below.
1. ping response will go to 192.168.2.1
2. other traffice will go to 203.10.10.1
Latchum Naidu
What you are looking to achive?
Do you plan to send only ICMP traffic in one way and all other traffic should use another way?
Please rate the helpfull posts.
Naidu.
If Naidu suggestion is right then the tool you need is PBR aka  policy routing.
http://www.cisco.com/en/US/products/ps6599/products_white_paper09186a00800a4409.shtml
Regards.
Alain.
Yes Naidu, ICMP from/to certain IP goes one way. Other traffic goes the other.
Thanks.
