12-13-2019 06:41 AM - edited 12-13-2019 06:43 AM
Extended ping sweep to remote end of GRE/IPSec tunnel df-bit set, mtu sizes 731-746 fail across WAN.
mtu sizes 64 - 730 work
mtu sizes 747 -1496 work
Same results from either side of the connection.
If I ping sweep my remote router physical interface with df-bit set, mtu sizes 64 - 1496 - results successful.
Our edge routers sub-interfaces have ip mtu 1496 set and the tunnel interface shows the ip mtu of 1476.
The end-results is our web applications fail.
Is there some reason -obvious or not -why pinging the non-tunnel address across the wan works while the tunnel addresses fail?
Communication across backup wan works.
Frank
12-13-2019 07:34 PM
Hello @fsebera ,
nice to see you again in the forums.
let us recap your findings:
I have few questions for you Frank,
what exactly type of GRE over IPSec are you using ?
I mean we know GRE header is 24 bytes I can guess your WAN interface is a Vlan based subif because of ip mtu 1496 (4 bytes used by 802.1Q IEEE Vlan tag)
Do you use both AH and ESP ?
Are you in tunnel mode ?
what kind of HMAC and ESP encryption are you using ?
payload DF should be copied to outer GRE header and then it should be copied to the more external IPSec header if using AH.
@fsebera may you provide more details on your network environment in order to get better help ?
Ciao Frank Merry Xmas and Happy New Year
Hope to help
Giuseppe
12-16-2019 06:39 AM
Hi Giuseppe,
Seems here, I only get the strange issues .... :-|
We are running IPSec over GRE (sorry for any confusion). No AH, just standard ESP with point-to-point tunnels.
As the PE, we strip any DF parameters from all pre-frag packets we receive from our business partners and it appears our WAN SPs drop any of our CE packets over 14~~ bytes or so- this is normal and acceptable. Our business partners do a great job of ensuring their packets don't need to be chopped.
We are attempting to determine if the WAN SP boxes have an OS bug or just a piss-poor miss-configuration.
Thanks and Happy Holidays to you too!!
Frank
