Cisco sg300-10
rsd16
Hi there,
How do i connect to a SG300-10 to do configuration?
I try http using the default ip, but i can not connect.
How do i connect to the switch physically? By using a straight network cable? Directly to one of the port?
rsd16
not sure what you have already tried, but have a look at the guide below. You need a straight (regular) Ethernet cable.
https://www.cisco.com/c/en/us/support/docs/smb/switches/cisco-small-business-200-series-smart-switches/smb66-initial-configuration-on-200-300-series-managed-switches.html
secureitgroup
I have one of these and rather than using a traditional baby blue console cable they use a serial cable, connecting is pretty much identical but you will need to adjust the baud rate to 115200.
