Ping Test fails?
Earthwarder
I'm having some problems with this packet tracker. I cannot ping test anything.
Everything is ready to go, well so I thought. It's a simple request but I'm still learning. Thanks in advance.
This is what it looks like: http://i.imgur.com/AD3dD0q.jpg
And here is some further information: http://pastebin.com/DEX6yvxJ - http://pastebin.com/ndjThMzYhttp://pastebin.com/a8wNFHw5
saif musa
Level 4
Level 4
Did you chicked routing table ? try to upload the result from ( show  ip route ) here please ..
Hello, thanks for reply! Is this what you mean?
R1#show ip route
Codes: C - connected, S - static, I - IGRP, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
i - IS-IS, L1 - IS-IS level-1, L2 - IS-IS level-2, ia - IS-IS inter area
* - candidate default, U - per-user static route, o - ODR
P - periodic downloaded static route
Gateway of last resort is not set
100.0.0.0/30 is subnetted, 3 subnets
C 100.0.0.0 is directly connected, FastEthernet0/0
C 100.0.0.4 is directly connected, FastEthernet0/1
R 100.0.0.8 [120/1] via 100.0.0.2, 00:00:12, FastEthernet0/0
165.100.0.0/26 is subnetted, 2 subnets
C 165.100.0.0 is directly connected, FastEthernet1/0
R 165.100.0.64 [120/1] via 100.0.0.2, 00:00:12, FastEthernet0/0
R2#show ip route
R 100.0.0.4 [120/1] via 100.0.0.1, 00:00:04, FastEthernet0/0
C 100.0.0.8 is directly connected, FastEthernet0/1
R 165.100.0.0 [120/1] via 100.0.0.1, 00:00:04, FastEthernet0/0
C 165.100.0.64 is directly connected, FastEthernet1/0
R3#show ip route
100.0.0.0/30 is subnetted, 2 subnets
C 100.0.0.4 is directly connected, FastEthernet0/0
165.100.0.0/26 is subnetted, 1 subnets
C 165.100.0.128 is directly connected, FastEthernet1/0
