Ping time out
rabienafaa
Hey folks,
I am just in the beginning of the networks learning process and I just had an error while creating a routing network scheme. First, I created a set of networks that are connected to each others through routers. Second, I used the ip route command in the CLI console in each router to make the routing static. Third, when I try to ping from PC0 to Server0 for example in the command prompt I get this which clearly shows I made a mistake somewhere but still didn't find out :
PC>ping 212.217.1.0
Pinging 212.217.1.0 with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 212.217.1.0:
Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
Your help is much appreciated !
PS : For a clearer view of my ping issue here is my project file below.
Joseph W. Doherty
I didn't try to open your attachment, but do your hosts have gateway IPs defined?
In fact, I just gave each host an IP adress and a subnet mask only. Here are two screenshots to clarify :
Ok, see if you can find a setting for the gateway IP, and use the router's interface IP on the shared network.
