ping to router from switch Un-sucessfull ?
1) configured router with sub-interfaces and assigned vlan's to every sub-interface using dot1q
2)configured switch ports with vlan's and attachd Pc's to every vlan.
3)pc's from all vlan can ping all the subinterface and other vlans's.
4)I can't ping the router sub-interfaces from the switch
do we have to configure any more on switch or router to make switch ping all the router sub-interfaces?
5 Accepted Solutions
paolo bevilacqua
I suppose it's a purely layer 2 switch that you're talking about. If so, configure "ip default-gateway x.x.x.x" on the switch where x.x.x.x is router address in vlan 1 (native).
Please rate post if it helps!
Kiran
You need to configure an IP address for VLAN 1 to enable ping from the switch to the router. As has been suggested you also need a default-gateway configured if you want the switch to access anything outside the subnet of its management interface.
Rick
Rick
Your switch is running as a pure L2 switch.
You need to configure L3 interfaces -SVIs- on the switch with for each vlan you want to ping.
int vlan x
ip add [][]
only after that you can ping from the sw.
Hi There
As p.bevilacqua said above. Your switch is purely a layer 2 switch at present.
You need to do the folowing.
a). Decide on an IP subnet for your device management.
b). Create another sub interface on your router and assign it the first IP address from your management subnet.
c). Assign the second IP address from your management subnet to the VLAN1 SVI on the switch.
d). Configure a default gateway on the switch. The default gateway IP address should be the IP address assigned to the sub interface on the router which has the first IP address of the management subnet.
Best Regards,
Michael
Kiran
Posting the router config is helpful. It shows that you do not have anything configured on the router on FastEther0/0 for VLAN 1. VLAN 1 is the management interface of the switc. If the router does not have VLAN 1 configured with an IP address that matches the subnet used on the switch then the switch will not be able to ping the router (or anything else in the network).
Note that not having an interface on the router for VLAN 1 only impacts traffic from the management interface of the switch. All the switch ports and all the devices connected to user VLANs on the switch will still work ok. But the switch itself will not be able to access anything without VLAN 1 configured and active on the router.
Rick
Rick
10 Replies 10
paolo bevilacqua
a.alekseev
Level 7
Level 7
show the switch's configuration
Building configuration...
Current configuration : 1759 bytes
version 12.1
hostname Switch
enable secret x $xxxxxxxxxxxxxx./
enable password xxxxxxx
interface FastEthernet0/1
switchport mode trunk
interface FastEthernet0/2
switchport access vlan 2
switchport mode access
interface FastEthernet0/3
switchport access vlan 3
interface FastEthernet0/4
switchport access vlan 4
interface FastEthernet0/5
switchport access vlan 5
interface FastEthernet0/6
switchport access vlan 6
interface FastEthernet0/7
switchport access vlan 7
interface FastEthernet0/8
switchport access vlan 8
interface FastEthernet0/9
switchport access vlan 9
interface FastEthernet0/10
switchport access vlan 10
interface FastEthernet0/11
switchport access vlan 11
interface FastEthernet0/12
switchport access vlan 12
interface FastEthernet0/13
switchport access vlan 13
interface FastEthernet0/14
switchport access vlan 14
interface FastEthernet0/15
switchport access vlan 15
interface FastEthernet0/16
switchport access vlan 16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface Vlan1
no ip address
line con 0
password xxxxx
login
line vty 0 4
password xxxxxx
login
line vty 5 15
password xxxxxx
login
end
Kiran
Rick
Rick
int vlan x
ip add [][]
Hi There
Best Regards,
Michael
Router configuration
interface FastEthernet0/0
no ip address
duplex auto
speed auto
interface FastEthernet0/0.1
description VLAN-2
encapsulation dot1Q 2
interface FastEthernet0/0.2
description VLAN-3
encapsulation dot1Q 3
ip address 192.168.2.1 255.255.255.0
interface FastEthernet0/0.3
description VLAN-4
encapsulation dot1Q 4
ip address 192.168.3.1 255.255.255.0
interface FastEthernet0/0.4
description VLAN-5
encapsulation dot1Q 5
ip address 192.168.4.1 255.255.255.0
interface FastEthernet0/0.5
description VLAN-6
encapsulation dot1Q 6
ip address 192.168.5.1 255.255.255.0
interface FastEthernet0/0.6
description VLAN-7
encapsulation dot1Q 7
ip address 192.168.6.1 255.255.255.0
interface FastEthernet0/0.7
description VLAN-8
encapsulation dot1Q 8
ip address 192.168.7.1 255.255.255.0
interface FastEthernet0/0.8
description VLAN-9
encapsulation dot1Q 9
ip address 192.168.8.1 255.255.255.0
interface FastEthernet0/0.9
description VLAN-10
encapsulation dot1Q 10
ip address 192.168.9.1 255.255.255.0
interface FastEthernet0/0.10
description VLAN-11
encapsulation dot1Q 11
ip address 192.168.10.1 255.255.255.0
interface FastEthernet0/0.11
description VLAN-12
encapsulation dot1Q 12
ip address 192.168.11.1 255.255.255.0
interface FastEthernet0/0.12
description VLAN-13
encapsulation dot1Q 13
ip address 192.168.12.1 255.255.255.0
interface FastEthernet0/0.13
description VLAN-14
encapsulation dot1Q 14
ip address 192.168.13.1 255.255.255.0
interface FastEthernet0/0.14
description VLAN-15
encapsulation dot1Q 15
ip address 192.168.14.1 255.255.255.0
interface FastEthernet0/0.15
description VLAN-16
encapsulation dot1Q 16
ip address 192.168.15.1 255.255.255.0
no ip address
duplex auto
speed auto
shutdown
interface Vlan1
no ip address
router eigrp 100
network 192.168.1.0
network 192.168.2.0
network 192.168.3.0
network 192.168.4.0
network 192.168.5.0
network 192.168.6.0
network 192.168.7.0
network 192.168.8.0
network 192.168.9.0
network 192.168.10.0
network 192.168.11.0
network 192.168.12.0
network 192.168.13.0
network 192.168.14.0
network 192.168.15.0
network 192.168.16.0
no auto-summary
Kiran
Rick
Rick
HI Guy's
Thanks, you'R Suggestions helped me a lot.I have rated you all guys thanks once again
Kiran
Thank you for the appreciation and good luck!
