pinging problem
jakubbylica
Community Member
Hey.
I've got into the cisco packet tracer recently, and I somehow managed to successfully use the RIP method. Yet now I wanted to implement it to more routers than 2. So here's my problem: I can ping the routers but I can't ping other computer in other networks. Here's a photo of my network, if it somehow helps you solve my problem. Thank you in advance!
make sure you configured all client networks in RIP correctly. also check if clients configured with correct IP / gateway configurations.
Good luck
KB
balaji.bandi
Are you running RIP on all Routers ?
Do you see the destination IP range learned in routing table ?
from the source device are you able to ping gateway ?
from the source device are you able to ping next router gateway ?
when you do tracert from device to destination, where it stop that where you need to loom why routing not taking place.
end device have any FW ?
BB
Good luck
KB
