Pinging, Tacacs, Radius, HSRP, Firewall Issues
daniel_growth
Hi All,
I have had a few issues with my Packet tracer network recently. I am unable to ping my corp lan through my firewall also.
The next main issue is I need to configure AAA on my layer 3 switches. I feel like they are only acting as layer 2.
If you could take a look at my packet tracer file and try to troubleshoot with me it would be great.
admin is username and cisco is password.
As a requirement I need all switches to use the radius/tacacs server 10.10.15.7 and have the option to use local if the server is down.
Traffic needs to travel from the lower networks through the firewall and back.
Another issue I have encountered is the HSRP complaining the standby states are incorrect or IP's are not set correctly.
Thanks in advance!
Kind Regards,
Daniel Growth
28 Replies 28
Hello
What version of PT are you using, I dont seem to be able to open that file you have attached
Kind Regards
Paul
Hey Paul. I'm using 7.2.2
Kind Regards,
Daniel Growth
you have made some changes to the original design that seem to make the network malfunctioning. The security level on the ASA outside interface is set to 100, why is that ? Your S2 switch cannot even be accessed because you misconfigured the HSRP for Vlan 10 ? And what are you trying to ping from the switches, still Loopback 1 (172.168.1.100) ? Also, you have added a default route to the ASA that causes to not send the default route to the OSPF neighbor. You are also missing the 'default-information originate' on the ASA under the OSPF process.
If you still have the original design I sent you, have a look at the configs, basic connectivity was established with that design.
AAA new model seems to be accepted on S1, What are you trying to configure ?
Hey @Georg Pauwen
The design you sent me would never allow me to ping the corp_lan/loopback_1
None of the switches have AAA configured to use 10.10.15.7 as the radius/tacacs server which i really want.
If you ping from the switches 1-6 to various locations you will struggle. I cant say that your file you sent fixed these issues so i tried myself. I got some things working for example I can ping the 192.168.1.1-2 address from S1 which i could before.
OSPF seems to just cause me issues. Id rather use static routes as I cant see the addresses changing in future. If you are able to get any of this fixed and sent back I would appreciate and I can learn from the new config.
Kind Regards,
Daniel Growth
the reason why the original design doesn't work for you is because the ASA apparently does not save the configuration when the project file is sent. That is why I sent you the configuration numerous times, but for some reason, you don't apply it. Here it is again:
ASA Version 9.6(1)
hostname ciscoasa
domain-name wr
names
interface Port-channel1
no nameif
no security-level
no ip address
interface GigabitEthernet1/1
nameif OUTBOUND
security-level 0
interface GigabitEthernet1/2
description Link to S1
nameif INBOUND
security-level 100
ip address 10.10.15.20 255.255.255.224
interface GigabitEthernet1/3
description Link to S2
nameif inside2
security-level 100
ip address 10.10.15.21 255.255.255.224
shutdown
interface GigabitEthernet1/4
no nameif
no security-level
no ip address
shutdown
interface GigabitEthernet1/5
no nameif
no security-level
no ip address
shutdown
interface GigabitEthernet1/6
no nameif
no security-level
no ip address
shutdown
interface GigabitEthernet1/7
no nameif
no security-level
no ip address
shutdown
interface GigabitEthernet1/8
no nameif
security-level 0
no ip address
channel-group 1 mode on
shutdown
interface Management1/1
management-only
no nameif
no security-level
no ip address
object network inside-subnet
subnet 10.10.15.0 255.255.255.224
route OUTBOUND 0.0.0.0 0.0.0.0 192.168.1.2 1
access-list OUTBOUND extended permit ip any any
access-group OUTBOUND in interface OUTBOUND
nat (INBOUND,OUTBOUND) dynamic interface
class-map inspection_default
policy-map global_policy
class inspection_default
inspect icmp
telnet timeout 5
ssh timeout 5
router ospf 1
log-adjacency-changes
network 0.0.0.0 255.255.255.255 area 0
ciscoasa#
After you have changed the ASA firewall configuration, the output of 'show run' must match what I sent you exactly.
I did apply it numerous times but it didn't work.
Your HSRP setup has a virtual IP or 10.10.10/15/20.3 but this range is already taken by S3 so i had to change it.
The TACACS+ issue is fixed. HSRP is fixed. Its just the firewall with the issue. I would be willing to have GI0/2-3 as 1.1.1.1/2.2.2.2 if it means it works. Also the 172 range corp_lan has been removed and replaced with 192.168.1.2.
Kind Regards,
Daniel Growth
post the output of 'show run' from the firewall, with what you currently have configured. Don't send the file, as the ASA seems to not save the configuration when the project file is being saved.
This will have changed allot since as i have been trying to fix it.
ASA:
ASA Version 9.6(1)
hostname firewall
domain-name wr
enable password 4IncP7vTjpaba2aF encrypted
names
no nameif
no security-level
no ip address
nameif OUTBOUND
security-level 100
nameif INBOUND
security-level 100
ip address 1.1.1.1 255.0.0.0
nameif inside2
security-level 100
shutdown
no nameif
no security-level
no ip address
shutdown
no nameif
no security-level
no ip address
shutdown
no nameif
no security-level
no ip address
shutdown
no nameif
no security-level
no ip address
shutdown
no nameif
security-level 0
no ip address
shutdown
management-only
no nameif
no security-level
no ip address
route INBOUND 0.0.0.0 0.0.0.0 10.10.15.2 1
route INBOUND 0.0.0.0 0.0.0.0 10.10.15.1 1
access-list INBOUND extended permit ip any any
aaa authentication ssh console LOCAL
ntp server 10.10.15.7
username admin password 4IncP7vTjpaba2aF encrypted
inspect icmp
telnet timeout 5
ssh timeout 5
router ospf 1
network 0.0.0.0 0.0.0.0 area 0
S1:
version 16.3.2
no service timestamps log datetime msec
no service timestamps debug datetime msec
service password-encryption
hostname S1
enable secret 5 $1$mERr$hx5rVt7rPNoS4wqbXKX7m0
aaa new-model
aaa authentication login tacacs+ group tacacs+ local
no ip cef
ip routing
no ipv6 cef
username admin privilege 15 secret 5 $1$mERr$hx5rVt7rPNoS4wqbXKX7m0
username user secret 5 $1$mERr$hx5rVt7rPNoS4wqbXKX7m0
ip ssh version 2
no ip domain-lookup
ip domain-name AE
spanning-tree mode rapid-pvst
switchport trunk allowed vlan 10,15,20
switchport mode trunk
interface GigabitEthernet1/0/1
interface GigabitEthernet1/0/2
switchport nonegotiate
interface GigabitEthernet1/0/3
channel-group 1 mode active
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
interface GigabitEthernet1/0/13
interface GigabitEthernet1/0/14
interface GigabitEthernet1/0/15
interface GigabitEthernet1/0/16
interface GigabitEthernet1/0/17
interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
interface GigabitEthernet1/0/23
interface GigabitEthernet1/0/24
interface GigabitEthernet1/1/1
interface GigabitEthernet1/1/2
interface GigabitEthernet1/1/3
interface GigabitEthernet1/1/4
interface Vlan1
no ip address
shutdown
interface Vlan10
description Dev_VLAN
mac-address 0030.a3d7.7d01
ip address 10.10.10.1 255.255.255.192
standby 10 ip 10.10.10.12
standby 10 priority 110
standby 10 preempt
interface Vlan15
description Mgmt_VLAN
mac-address 0030.a3d7.7d02
ip address 10.10.15.1 255.255.255.224
standby 15 ip 10.10.15.12
standby 15 priority 110
standby 15 preempt
interface Vlan20
description VSAN_Vlan
mac-address 0030.a3d7.7d03
ip address 10.10.20.1 255.255.255.0
standby 20 ip 10.10.20.12
standby 20 priority 110
standby 20 preempt
router ospf 1
network 172.168.1.0 0.0.0.0 area 0
network 192.168.1.0 0.0.0.0 area 0
ip default-gateway 10.10.15.12
ip classless
ip route 192.168.1.0 255.255.255.0 1.1.1.1
ip flow-export version 9
tacacs-server host 10.10.15.7 key cisco
line con 0
password 7 0822455D0A16
logging synchronous
login authentication tacacs+
line aux 0
logging synchronous
line vty 0 4
logging synchronous
transport input ssh
line vty 5 15
transport input ssh
ntp authenticate
ntp trusted-key 12345
ntp server 10.10.10.7
end
S2:
version 16.3.2
hostname S2
aaa new-model
no ip cef
ip routing
no ipv6 cef
ip ssh version 2
no ip domain-lookup
ip domain-name AE
interface Vlan1
no ip address
shutdown
interface Vlan10
mac-address 0010.11c3.0601
ip address 10.10.10.2 255.255.255.192
interface Vlan15
mac-address 0010.11c3.0602
ip address 10.10.15.2 255.255.255.224
interface Vlan20
mac-address 0010.11c3.0603
ip address 10.10.20.2 255.255.255.0
router ospf 1
ip classless
line con 0
logging synchronous
line aux 0
logging synchronous
line vty 0 4
logging synchronous
transport input ssh
line vty 5 15
transport input ssh
ntp authenticate
end
Kind Regards,
Daniel Growth
unfortunately, there are still many, many misconfigurations, too many to comment on actually. I have corrected everything and marked the important parts in bold.
Try to make the running configs of your devices look EXACTLY like those below:
ASA:
ASA Version 9.6(1)
hostname firewall
domain-name wr
names
no nameif
no security-level
no ip address
nameif OUTBOUND
security-level 0
nameif INBOUND
security-level 100
nameif inside2
security-level 100
shutdown
no nameif
no security-level
no ip address
shutdown
no nameif
no security-level
no ip address
shutdown
no nameif
no security-level
no ip address
shutdown
no nameif
no security-level
no ip address
shutdown
no nameif
security-level 0
no ip address
shutdown
management-only
no nameif
no security-level
no ip address
access-group INBOUND in interface OUTBOUND
inspect icmp
telnet timeout 5
ssh timeout 5
router ospf 1
S1:
version 16.3.2
hostname S1
aaa new-model
no ip cef
ip routing
no ipv6 cef
ip ssh version 2
no ip domain-lookup
ip domain-name AE
no switchport
ip address 1.1.1.2 255.0.0.0
interface Vlan1
no ip address
shutdown
interface Vlan10
standby 10 preempt
interface Vlan15
standby 15 preempt
interface Vlan20
standby 20 preempt
router ospf 1
ip classless
line con 0
logging synchronous
line aux 0
logging synchronous
line vty 0 4
logging synchronous
transport input ssh
line vty 5 15
transport input ssh
ntp authenticate
end
S2:
version 16.3.2
hostname S2
aaa new-model
no ip cef
ip routing
no ipv6 cef
ip ssh version 2
no ip domain-lookup
ip domain-name AE
interface Vlan1
no ip address
shutdown
interface Vlan10
interface Vlan15
interface Vlan20
router ospf 1
ip classless
line con 0
logging synchronous
line aux 0
logging synchronous
line vty 0 4
logging synchronous
transport input ssh
line vty 5 15
transport input ssh
ntp authenticate
end
nameif INBOUND
security-level 100
nameif inside2
security-level 100
shutdown
How come 1/3 hasnt been changes. The same for S2?
Kind Regards,
Daniel Growth
That is because I don't know what you want to do with the IP addressing. If you want to use this interface as well, configure it with an IP address, and the connecting interface on S2 as 'no switchport' and with an IP address from the same space. You also need to add a NAT entry for that interface, similar to the NAT entry you already have for the other interface.
nameif inside2
security-level 100
ip address 2.2.2.2 255.0.0.0
@Georg Pauwen
Progress!
I can ping to corp lan through S1. I am struggling to ping from the other switches including S2.
Also some of my switches are now unable to ping 10.10.15.7.
Could you take a look and see if you could maybe correct some of the connection issues so that everything is able to ping. I dont think there are any major issues. Just some that i may have missed. I am very nearly complete now.
I will need to add ACL's to some switches to prevent vlan 20 speaking to vlan 10 on switches 3 and 4.
Kind Regards,
Daniel Growth
I cannot access the devices because you have changed the login information.
Either way, make sure the OSPF neighbors between S1, S2, and the ASA work. On the ASA, configure:
router ospf 1
and on both switches:
router ospf 1
On the switches, there should be no other stat.ic routes or default gateways
