08-17-2007 08:13 AM - edited 03-03-2019 06:22 PM
Hello all,
I have 2 WAN Connections.
1=Broadband connection with static IP (172.23.14.2)
2=T-1 connection with static IP (172.23.14.1)
I want all traffic to default to the Broadband connection (172.23.14.2) but I need a few IPs to route over to the T-1. The IPs I need to route to the T-1 are...
128.1.0.3
172.16.0.154
192.168.192.37
How & where to I enter this information? I only have the GUI interface to work with.
In the PDM I have the following setup and it is not working...
Under the Configuration - Host/Networks tab I've added an Outside Interface named Blah with the following specs.
Basic Info
IP = 128.1.0.3
Mask = 255.255.255.255
Int = outside
Name = Blah
Routing
Checked Define Static Route
Gateway IP = 172.23.14.1
Metric = 2
I have the same setup for the other 2 IPs as well(with different names). I've applied the command and saved the router config and it still doesn't route.
FYI, I changed the Interface to also be Inside just in case and it did not change any of the final results.
Thank you in advance for your assistance!!!!!
08-17-2007 08:33 AM
Here is my config. FYI, I've replaced passwords with zzzzz & our outside Interface with x.x.x.x
Result of firewall command: "sh run"
: Saved
PIX Version 6.3(5)
interface ethernet0 auto
interface ethernet1 100full
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password zzzzz encrypted
passwd zzzzz encrypted
hostname pixfirewall
domain-name ciscopix.com
clock timezone EST -5
clock summer-time EDT recurring
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
names
name 128.1.0.3 blah
access-list inside_outbound_nat0_acl permit ip any 172.23.14.128 255.255.255.192
access-list inside_outbound_nat0_acl permit ip any 172.23.14.160 255.255.255.224
access-list outside_access_in permit tcp any interface outside eq 3389
pager lines 24
mtu outside 1500
mtu inside 1500
ip address outside x.x.x.x 255.255.255.252
ip address inside 172.23.14.2 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
ip local pool vpnpool 172.23.14.151-172.23.14.160
pdm location 172.23.14.0 255.255.255.0 inside
pdm location 65.165.202.144 255.255.255.248 outside
pdm location 204.118.126.3 255.255.255.255 outside
pdm location 204.181.35.98 255.255.255.255 outside
pdm location 204.249.224.128 255.255.255.192 outside
pdm location 24.106.195.64 255.255.255.192 outside
pdm location 24.106.200.64 255.255.255.248 outside
pdm location 192.168.1.0 255.255.255.0 inside
pdm location 172.23.14.5 255.255.255.255 inside
pdm location 172.23.14.160 255.255.255.224 outside
pdm location 172.23.14.128 255.255.255.192 outside
pdm location blah 255.255.255.255 outside
pdm logging informational 100
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list inside_outbound_nat0_acl
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
static (inside,outside) tcp interface 3389 172.23.14.5 3389 netmask 255.255.255.255 0 0
access-group outside_access_in in interface outside
route outside 0.0.0.0 0.0.0.0 24.38.95.117 1
route outside Meditech 255.255.255.255 172.23.14.1 2
timeout xlate 0:05:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout sip-disconnect 0:02:00 sip-invite 0:03:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server TACACS+ max-failed-attempts 3
aaa-server TACACS+ deadtime 10
aaa-server RADIUS protocol radius
aaa-server RADIUS max-failed-attempts 3
aaa-server RADIUS deadtime 10
aaa-server LOCAL protocol local
http server enable
http 204.181.35.98 255.255.255.255 outside
http 24.106.195.64 255.255.255.192 outside
http 24.106.200.64 255.255.255.248 outside
http 192.168.1.0 255.255.255.0 inside
http 172.23.14.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
sysopt connection permit-ipsec
sysopt connection permit-pptp
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
isakmp enable outside
isakmp enable inside
telnet 172.23.14.0 255.255.255.0 inside
telnet 192.168.1.0 255.255.255.0 inside
08-17-2007 08:33 AM
telnet timeout 5
ssh timeout 5
console timeout 0
vpdn group PPTP-VPDN-GROUP accept dialin pptp
vpdn group PPTP-VPDN-GROUP ppp authentication mschap
vpdn group PPTP-VPDN-GROUP ppp encryption mppe auto required
vpdn group PPTP-VPDN-GROUP client configuration address local vpnpool
vpdn group PPTP-VPDN-GROUP pptp echo 60
vpdn group PPTP-VPDN-GROUP client authentication local
vpdn username administrator password *********
vpdn username helpdesk password *********
vpdn username mblackburn password *********
vpdn username bseiss password *********
vpdn username rviola password *********
vpdn username moc2 password *********
vpdn enable outside
vpdn enable inside
dhcpd lease 3600
dhcpd ping_timeout 750
dhcpd auto_config outside
terminal width 80
Cryptochecksum:zzzzz
: end
08-20-2007 07:08 AM
Just checking to see if anyone can assist me with this problem. If I'm in the incorrect forum please let me know.
Cordially,
Chris
