pix firewall nat question
simaskvilius
I'm learning to configure cisco pix firewallas and found following global NAT pool example in cisco page:
global (outside) 1 200.100.100.110-200.100.100.150 netmask 255.255.255.0
I'm wondering why cisco in examples netmask field is included besides the address range. (it is obvious when it is included beside single IP, but with address range it is something nonsensical )
shivlu jain
Level 5
Level 5
Its not a nonsensical because with the netmask you can define the range
regards
shivlu
What range ?
Range is already difined in statement 200.100.100.110-200.100.100.150 (from 110 to 150)
What if you DON'T want to NAT 200.100.100.115/22?
The NAT statement 200.100.100.110-200.100.100.150 netmask 255.255.255.0 will only NAT 200.100.100.110-150/24.
It won't NAT the same IP address with a different mask. Therefore it allows for greater control over the NAT.
Hope that helps.
kittu.mbk
hi dude
cisco wants it's students to be very clear about what they are learning, and no specific reason for it.
any way my yahoo id is kittumcp@yahoo.com.
hope we discuss more issues
