PIX OSPF router priority
aruzsinszky
How can I change the router priority on PIX 501 (6.3)? I didn't find. :-(
Is that possible?
TIA,
5 Replies 5
Jon Marshall
I don't have a pix handy but according to this table the command is "ip ospf priority" and it is supported on 6.3 -
http://www.cisco.com/en/US/docs/security/pix/pix63/configuration/guide/bafwcfg.html#wp1112587
I did look at the command reference for 6.3 and couldn't find it though so no guarantees :-)
Jon
pix# conf t
pix(config)# ip ospf priority 3
Invalid keyword: "ospf"
Usage: [no] ip address []
[no] ip address pppoe [setroute]
[no] ip address dhcp [setroute] [retry ]
ip local pool [-] [mask ]
ip verify reverse-path interface
ip audit {info|attack} action [alarm] [drop] [reset]
ip audit name {info|attack} [action [alarm] [drop] [reset]]
ip audit interface
ip audit signature disable
show|clear ip audit count [global] [interface ]
show ip [address [ [pppoe|dhcp [lease|server]]]]
pix(config)#
Did I make any mistakes?
TIA,
You need to go into your OSPF process configuration first ie.
pix(config)# router ospf
pix(config-router)# ip ospf priority 3
Jon
TIA,
Well it may not be supported - try
pix(config-router)# ospf priority 3
or
pix(config-router)# priority 3
Jon
