PIX SNMP configs
egitonga1978
Dear All,
i need some help on enabling cisco PIX snmp. I have use the following commands but nothing is working :
snmp-server host outside x.x.x.x
snmp-server host inside x.x.x.x
no snmp-server location
no snmp-server contact
snmp-server community private
snmp-server enable traps
kindly assist.
Elias
satish_zanjurne
Level 4
Level 4
Hi Elias ,
Kindly check on inside interface first with following commands & then check for outside interface.
snmp-server enable
snmp-server host inside 192.168.3.2
snmp-server community key
snmp-server enable traps all
Also addd
logging enable
The default configuration has all snmp traps enabled.
HTH..rate if helpful..
