Pl suggest a router
gkirankumar
Our company is planning to upgrade the CISCO 1721 routers at our remote offices, for connecting to VPN with the main office. We need a router with the following ports:
1) ISDN Dial up port
2) Two Ethernet ports
3) At least one serial port
We use VPN only for sending/receiving data and not for voice / video. Bandwidth at each remote office is 128 Kbps and we may scale it upto 2Mbps Maximum.
Please suggest me good routers, which have a product life of 6 yrs.
Thanks in advance.
2 Accepted Solutions
Check the Cisco Product Advisor tool to find the product matching your requirements.
http://www.ciscowebtools.com/productadvisor/routers.asp
senthuran
rskrzek
I suggest 1841 ISR modular router bundle - CISCO1841-SEC/K9 with BRI ans T1/E1 serial WICs. This boundle has onboard VPN accelerator and IOS with crypto feature. Please verify on http://www.cisco.com/en/US/prod/collateral/routers/ps5853/product_data_sheet0900aecd8016a59b.html
regards
romek
Goutam Sanyal
Level 4
Level 4
You can visit the bellow url or can download the pdf. Where you will find all the required information for cisco router only.
http://www.cisco.com/en/US/prod/collateral/routers/ps5855/prod_brochure0900aecd8019dc1f.pdf
Goutam
[pls rate if it helps]
