bgp local-as with no-prepend
devang_etcom
Level 7
Level 7
I am configuring to router connected with serial back to back and configuring one router with local-as no-prepend option but still i am seeing original AS number and loca-as configured AS number in the remote router bgp table. why?
regards
Devang Patel
Harold Ritter
Devang,
This is normal behavior. Try adding the replace-as keyword at the end of the local-as command.
Refer to the following documentation for more information:
http://www.cisco.com/en/US/docs/ios/12_3t/12_3t11/feature/guide/gtbgpdas.html#wp1053187
Edison Ortiz
Can you post config along with the BGP output?
__
Edison.
Harold Ritter
Devang,
Hritter,
thanks for your reply... I have never noticed that one...
regards
Devang Patel
