03-17-2016 03:54 AM - edited 03-05-2019 03:35 AM
Hello. Help me please.
I am try planing radio coverage for client.
I am want try using AP AIR-SAP2602E-E-K9 with antenna air-ant2566p4w-r.
It is stock, red frame - metal shelving gravitational type. In center one floor - it is tunnel.
Storage Product have not any metall or liquid.
I am plan install AP with antenna in angles, see please in attached file (mark green)
Tell me please, can work this variant?..
Thank You.
03-17-2016 06:58 AM
It looks like it is only 34m - and you are planning on using 4 access points? If so, don't bother with external antennas. The built in antennas would give you plenty of coverage over that range.
Note that the 2602 has been replaced by the 2702, and the model with built in antennas is the 2702i.
03-17-2016 07:52 AM
Hello, Philip.
Ok Thank You.
