Please advise to buy CISCO basic router
mailme.tester
Currently our project uses the Linux box as a router. we want to replace this Linux box to CISCO router.
We want to incorporate 4 such Linux box in to 1 single CISCO router.
Please advise, what model will be best for our requirement and cost.
Partha
Marwan ALshawi
what is your requirments
how many users?
how mauch WAN/internet bandwidth
what sort of physical interfaces you need/ fastethernet, gigethernet, Wireless ?
what other feaute you need, VOIP, security such as firwaling, VPN ?
any other requriments
then we can suggest you
or
you can consulate a local cisco Partner to give you a suggestion with a price
Hi Marwanshawi,
Thanks for your reply.
  • what is your requirments
          To analyse and test the internal clients traffic, this traffic can go internet as well.
  • how many users?
          Not more than 100 users
  • how much WAN/Internet bandwidth
          at least 1gbps
  • what sort of physical interfaces you need/ fastethernet, gigethernet, Wireless ?
         fastethernet or gigethernet,
  • what other feature you need, VOIP, security such as firewall, VPN ?
        No
    Please suggest me the suitable router.
    Partha
    there is one confusing thing
    what you mean by the WAN/Internet 1Gbps ?? i dont think you mean the line rate for sure ( assuming this for 100 users )
    with assumption above Cisco ISR router series 2951 could be useful for you or you might go with bigger one 3925 or 3945
    i recommend you contact a Cisco local partner for help in this one
    if helpful Rate
    Thanks for your info.
    On Mon, Jul 25, 2011 at 3:48 PM, marwanshawi <
