Please i need the command manual to configure C899G-LTE-GA-K9 for SIM
EDU1
I got this C899G-LTE-GA-K9 and want to configure it for SIM0 with MTN Nigeria.
Please can anyone upload the manual for configurations.
Thank you
balaji.bandi
check a couple of documents :
you need to build the config, and changes from provider to provider, once build and run debug if any issues and post to the forum we can help you based on the outputs.
https://www.cisco.com/c/en/us/td/docs/routers/access/interfaces/software/feature/guide/ehwic-4g-ltesw-book.html
https://wannabelab.blogspot.com/2016/04/cisco-899-4g-lte-router-configuration.html
http://networkingbodges.blogspot.com/2014/09/configuring-basic-4g-lte-connectivity.html
BB
