Pluggable module - possible to trigger reboot of the module on IOS XR?
k.limandvik
Is there any functionality on NCS 5500 / ASR9k allowing me to trigger boot of a pluggable module? (In my specific use case I'm using SFP+ on an NCS 57C3 in a TF-port and one of my tunable optics is stuck on ITU-ch 40 and the interface will not show up at all.
I've seen this issue before and fixed it by pulling and reinserting the SFP+, but as the device is over an hour away from my nearest office, I'd really prefer to reset only the affected device.
johnlloyd_13
Level 9
Level 9
hi,
to my knowledge, there's no command to reset the SFP in an NCS and ASR device.
you'll need to physically re-seat the SFP (pull it out/re-insert) and sometimes need to swap in case you've got a bad SFP or from a third party vendor.
best to always use a cisco genuine SFP to avoid interface/SFP from failing.
johnlloyd_13
Level 9
Level 9
hi,
k.limandvik
Thank you for your reply. I suspected as much but was worth a shot.
