POE on 3560CX
jbigrow
Hi Folks
I'm attempting to use some cisco 3560CX units attached to a juniper poe ++
switch which supplies power to the cisco 3560. On the 3560CX I want to attach
WAPS and IP phones. say 2 of each. I keep getting insufficient total power
and the devices do not come up except for the first device. I have both uplinks set to have POE. Is there a limit for the uplink ports? I also do not want to use a separate power supply for the 3560cx units only the uplinks
any advice?
jbigrow
I should ask  what is the maximum power I can get to the 3560cx via the uplinks only?
