point to multipoint configuration on routers
hello
we having 3 routers main location 2800 and remote location 1800 routers total 3 locations i want to configure point to multi point configuration on 3 locations i having leased line connectivity on 3 locations main location ip se 0/0/0 10.10.10.1,serial 0/0/1 10.10.10.2 eth 192.168.1.1 ,remote serial 0/0/0 10.10.10.3 eth 192.168.2.1 and another site serial 0/0/0 10.10.10.4 eth 192.168.3.1 i want 3 locations intranet configuration.
7 Replies 7
Giuseppe Larosa
Hello Ramnet,
for a point-to-multipoint communication you would need a FR WAN service because having a collection of leased lines is not enough to achieve this.
In the case you have bought access links to a FR service you can implement a classic hub and spoke topology with your central site acting as hub.
the FR service provider will give you the right DLCI to be used on each PVC.
You need three FR PVCs
Central site - remote site1
Central site - remote site2
Central site - remote site3
Hub router 2800
R2800#
int ser0/0
enc frame-relay
no ip address
int ser0/0.100 multipoint
ip address 10.10.10.1 255.255.255.0
frame-relay map ip 10.10.10.2 101 broadcast
frame-relay map ip 10.10.10.3 102 broadcast
frame-relay map ip 10.10.10.4 103 broadcast
Remote1
int ser0/0
enc frame-relay
no ip address
ip addr 10.10.10.2 255.255.255.0
frame-rel map ip 10.10.10.1 201 broadcast
you need a routing protocol to advertise the local client vlan subnets
using EIGRP or RIPv2 the central site needs split-horizon to be disabled
central site
router eigrp 100
network 10.0.0.0 0
no auto-summary
int ser0/0.100
no ip eigrp 100 split-horizon
on each remote (the EIGRP AS must be the same)
router eigrp 100
network 10.0.0.0
network 192.168.x.0
no auto-summary
x=1 for remote site1, 2 for remote site2 and so on
Hope to help
Giuseppe
My service provider is not providing FR service i should implement on ppp or hdlc only. please send me the suitable configuration for this application.
Hello Ramnet,
you need three distinct point to point serial connections from central site to each remote site.
3 serial interfaces on central site router
each point-to-point link will use a different ip subnet
10.10.10.0/30 CS - Remote1
10.10.10.4/30 CS - Remote2
10.10.10.8/30 CS - Remote3
int ser0/0/0
enc ppp
ip address 10.10.10.1 255.255.255.252
desc CS - remotesite1
int ser0/0/1
enc ppp
ip address 10.10.10.5 255.255.255.252
desc CS - remotesite2
int ser0/1/0
enc ppp
ip address 10.10.10.9 255.255.255.252
desc CS - remotesite3
on each remote site
int ser0/0
enc ppp
ip address 10.10.10.x 255.255.255.252
where x is:
2 for remote site1
6 for remote site2
10 for remote site3
Hope to help
Giuseppe
Dear Giuseppe
ip address 10.10.10.4 255.255.255.252
when i try to serial ip make 252 subnet its not taken i configured 3 sites plz find the attachments its connected 3 sites but some times its breaking connections,so plz advise me.configuration.
hello,
the router cannot accept
10.10.10.4 255.255.255.252 that is the subnet address
you need to use
please follow my previous post in the part of configuration of interfaces
However, I see that you haven't three serial links in main office so you can connect only two sites not three
Edit:
Now I see that there only three locations including central site you should be fine.
on main office
interface Serial0/0/0
no ip redirects
no ip mroute-cache
no cdp enable
interface Serial0/0/1
Hope to help
Giuseppe
Dear Giuseppe,
main office to two remote offices connectvity
i want to connectvity main office and remote 2 offices intranet connectvity i mean main office to remote 1 office ,main office to remote 2 office,and remote office to remote office total 3 locations must in intranet connectvity.
Hello Ramnet,
the configuration examples that I have provided are good for your scenario.
the key point is to use a different ip subnet in the two point-to-point links because they are distinct links.
just skip the config of the third link that is not needed
Hope to help
Giuseppe
