Point To Point Link Between HQ & Branch
I need help to configure point to point connectivity between two sites. Below is the current configuration.
-Branch range is 10.104.11.0/24
-Branch users Gateway is 10.104.11.1
-DNS should be the same as used in HQ site
-Active Ports on SGN switch on Branch are 15-19
-Active Port on SGN switch on HQ is 15
-You need to connect Port on HQ site to your core switch/Firewall
-The point to Point Link will be 10.104.12.0/30 where NBN is 10.104.12.1
Any help is greatly appreciate.
8 Replies 8
is this an excercise ? What equipment are you supposed to use ?
The original poster mentions a branch and HQ. But does not tell us anything about how they are connected. There is also mention of HQ core but no information about how that is connected. We need better information about the networking environment to be able to give good advice about this question.
Rick
Rick
I have Cisco Core Switch(L3) & ASA Firewall& Edge switch(L2) in HQ
also in branch site i have edge switch(L2) just.
I need to connect P2P link between ASA(HQ) and Edge switch(branch) by internet
If the branch has just a L2 switch then it is not routing and certainly would not have support for any encryption of traffic. I do not know of a way to have a successful point to point link to the branch.
Rick
Rick
Deepak Kumar
Your information is very less and there is no such question. What want to archive it and where is HQ details?
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
i want PCs in branch site to connect to other PCs in HQ
