Policy Base Routing
hs08
On our branch i have  2 path to the internet, 1st via local internet on the site and 2nd via Head Office via WAN.
All traffic to other branch, Head Office should pass thru via Head Office via WAN and all internet traffic including to Microsoft Azure (using VPN site to site) should use local internet and will failover to HO via WAN if the local connection is down.
On the core switch i make route-map like below
ip access-list extended Internal-DC
1 permit ip 10.0.0.0 0.255.255.255 10.0.0.0 0.255.255.255
ip access-list extended INET-VIA-FORTI
10 permit ip any any
route-map PBR-INET deny 10
match ip address Internal-DC
route-map PBR-INET permit 20
match ip address INET-VIA-FORTI
set ip next-hop 10.102.173.2
then i apply in vlan interface
interface Vlan101
ip address 10.102.1.1 255.255.255.0
ip ospf 100 area 0.0.0.102
ip policy route-map PBR-INET
also i have static route to our azure (10.201.0.0/16) to local internet
ip route 10.201.0.0 255.255.0.0 10.102.173.2
With above configuration all hosts under vlan 101 can access to the internet via local internet, can access to azure via local internet and also can access to other branch, HO via WAN. So everything is run normally until then i realized i have ACL
This ACL applied to the route map, and i my mind traffic to the azure with subnet 10.201.0.0/16 will match to this ACL and the traffic should be denied by route map
This mean traffic to the azure should routed to the HO via WAN even i have static route to 10.201.0.0/16 via local internet, am i right?
16 Replies 16
Joseph W. Doherty
Just wondering, if you're using OSPF and default originate, have you considered using it as a type 1?
Hello
@hs08 wrote:
With that configuration my logic say traffic only traffic to 10.201.0.0 will go to hop 10.102.173.2, am i correct?
What i want is :
  • Traffic to azure from all subnet go via 10.102.173.2
  • Traffic to other branch, HO will go via WAN
  • Traffic to internet from VLAN 100 will go via WAN
  • Traffic to internet from VLAN 101 will go to 10.102.173.2
No it should do what you require it to do, providing the default for all traffic without any PBR is routed via HQ nexthop and NOT internet breakout?
the full route-map should read..
ip access-list extended NET
permit ip any 10.201.0.0 0.0.255 255
route-map PBR-INET permit 5
match ip address NET
route-map PBR-INET permit 20  <  this is a catch all statement
Kind Regards
Paul
