Policy-based Routing and Secondary Interfaces
TODD BEERS
In order to do non-intrusive testing with an inline device between router and switch, we've set up the following:
Router
Int g0/0
ip address 10.1.1.1 255.255.255.252
ip address 192.168.1.2 255.255.255.248 secondary
Switch
int vl638
ip address 10.1.1.2 255.255.255.252
ip address 192.168.1.1 255.255.255.248 secondary
(Pending) ip route 10.17.0.0 255.255.0.0 192.168.1.2
The remote subnet we're using for testing is 10.17.0.0/16 and its destination subnets are in 10.1.0.0/16. I created the following PBR to avoid asymmetrical routing, but I haven't applied it yet. Most of the traffic is originated from the 10.17.0.0/16 end.
access-list 113 permit 10.17.0.0 0.0.255.255 any
route-map Testing permit 10
match ip address 113
set ip next-hop 192.168.1.1
int g0/0
ip policy route-map Testing
Will this ensure that all of the traffic flowing between 10.17.0.0/16 and 10.1.0.0/16 will hit 192.168.1.1 on the way in 1 and 92.168.1.2 on the way back out and not affect any other traffic?
Diana Karolina Rojas
Your configuration only ensure that all the traffic (to any subnet) from 10.17.0.0/16 hit 192.168.1.1, no more, If you only want to ensure the traffic from 10.17.0.0/16 to 10.1.0.0/16 hit the ip 192.168.1.1 you have to use an extended access list like this:
access-list 130
permit ip 10.17.0.0  0.0.255.255 10.1.0.0 0.0.255.255
PD: Remember rate useful answers.
access-list 130
Yeah I figured that would be the case. I'm actually going to start very narrow, then expand, so my initial ACL will be:
access-list 113
permit ip 10.17.3.0 0.0.0.255 10.1.0.0 0.0.255.255
Can't get any hits to the route map/acl even though I'm generating traffic that should match. Wondering if this just doesn't work with secondary addresses.
