Policy-Based routing raccomendation
mcardell
Good morning,
I am thinking to implement policy-based routing in my network.
I am sure that Cisco was not raccomending this type of routing before. The reason is that could create loop and it is not easy to maintain. But lately I have found few links that are using it as a feature. I wonder what is your experience and if there is any problem in implementing that.
Matteo
I have had no problem with policy based routing, obviously you have to know your network and what you want to do. if possible do a little at a time, and test test test. then you should be ok,
Richard.
