08-05-2025 10:57 PM - edited 08-05-2025 11:00 PM
Hi everyone. I have a 2960x acting as a "core" switch doing inter-vlan routing. Vlan 400 is for IoT. Other vlan hosts need to be able to access hosts in the iot vlan, no hosts in the iot vlan can access anything but internet. All hosts in the Iot vlan need to access the internet through an external VPN gateway on 172.16.30.42.
After configuring PBR, it works as expected. But when configured with reflactive ACL, things didn't work as expected.
configs:
ip access-list extended iot-1-in 5 evaluate iot-1-in-refl 10 deny ip any 10.0.0.0 0.255.255.255 log 20 deny ip any 172.16.0.0 0.15.255.255 log 30 deny ip any 192.168.0.0 0.0.255.255 log 40 permit ip any any ip access-list extended iot-1-out 10 permit ip any any log reflect iot-1-in-refl ip access-list extended vpn-pbr-acl1 10 deny ip any 10.0.0.0 0.255.255.255 20 deny ip any 172.16.0.0 0.15.255.255 30 deny ip any 192.168.0.0 0.0.255.255 40 permit ip any any route-map vpn-pbr1 permit 10 match ip address pbr-acl1 set ip next-hop 172.16.30.42 interface Vlan400 ip address 172.16.4.1 255.255.255.240 ip access-group iot-1-in in ip access-group iot-1-out out ip policy route-map vpn-pbr1
The PBR config works as expected, but reflective ACL don't.
- Hosts in the IoT vlan can ping internet, and cannot ping LAN addresses.
- Hosts not in the IoT vlan cannot ping hosts in IoT vlan
When I remove `ip policy route-map vpn-pbr1` the reflective ACL works as expected, but internet traffic no longer goes to the VPN gateway
When the route-map is in place, this is what shows when showing access-lists
Extended IP access list iot-1-in 5 evaluate iot-1-in-refl 10 deny ip any 10.0.0.0 0.255.255.255 log 20 deny ip any 172.16.0.0 0.15.255.255 log (1041 matches) 30 deny ip any 192.168.0.0 0.0.255.255 log 40 permit ip any any Reflexive IP access list iot-1-in-refl permit icmp host 172.16.4.2 host 172.16.3.2 log (2037 matches) (time left 299) Extended IP access list iot-1-out 10 permit ip any any reflect iot-1-in-refl log (1019 matches) Extended IP access list vpn-pbr-acl1 10 deny ip any 10.0.0.0 0.255.255.255 20 deny ip any 172.16.0.0 0.15.255.255 30 deny ip any 192.168.0.0 0.0.255.255 40 permit ip any any
Why is it matching a permit on the reflexive ACL yet it is matched again on sequence number 20 on iot-1-in. Also one of the things I encountered is that the implicit deny seems to not exists(allowing all traffic on empty access-list)
What have I missed on these 2 components and why is have of the things configured not work as expected.
Version:
Cisco IOS Software, C2960X Software (C2960X-UNIVERSALK9-M), Version 15.2(7)E12, RELEASE SOFTWARE (fc5) on WS-C2960X-24PS-L
08-05-2025 11:56 PM
Hello
Your ace 20 in the ACLs is also capturing vlan 400 subnet, this need to be excluded
Also a straight forward routed acl would be more applicable for this requirement
Note : SVI acl logic
IN = traffic originating from within vlan
OUT = external traffic towards vlan
IP access list extended vlan400_acl
deny ip any <vlan 1>
deny ip any <vlan 2>
etc
permit ip any
int vlan 400
no ip access-group iot-1-in in
no ip access-group iot-1-out out
ip access-group vlan400 IN
no 10
no 20
no 30
08-06-2025 12:13 AM
Thank you Paul for the reply, I'm not sure if I understand why vpn-pbr-acl1 need to seq:10,20,30 removed. If the ACL is not excluded, wouldn't packets destinated for Local Addresses be also routed to the VPN Gateway?
Another thing that still don't make sense to me is the evaluation of the inbound access-list. According to https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/sec_data_acl/configuration/15-mt/sec-data-acl-15-mt-book/sec-cfg-ip-filter.html#GUID-28D4B3F2-E213-4DF5-BBCB-D12B55E857F7
After an entry is match according to the sequence of the entries in an ACL, no more entries is matched. How is the packet ICMP echo reply matched on both the entry in the reflective ACL(permit imcp) and the seq:20 deny to local network.
08-06-2025 12:33 AM
match ip address pbr-acl1<<- this name is wrong
MHM
08-06-2025 12:39 AM
Hello
Yes it would, so apologies if that isnt what you intended i must have misread your OP - but if your denying access to all other vlan users within your LAN to access to vlan 400 then basically that vlan 400 becomes just a guest vlan solely needing to reach the internet- no ?
@Karl3 wrote:Another thing that still don't make sense to me is the evaluation of the inbound access-list.
I would say as the initial icmp originated internally, this would trigger a state-full session thus allowing a reply in the refl acl
08-06-2025 01:07 AM
route-map vpn-pbr1 permit 10 match ip address pbr-acl1. <----no reference to acl as per your post. Did you mean to match vpn-pbr-acl1 ?
In addition to above mentioned post check the acl is correct ?
08-07-2025 12:03 AM
Hi@Karl3
Please change acl
10 permit tcp any 10.0.0.0 0.255.255.255 established
20 deny ip any 10.0.0.0 0.255.255.255 log
30 deny ip any 172.16.0.0 0.15.255.255 log
40 deny ip any 192.168.0.0 0.0.255.255 log
50 permit ip any any
Thanks !
08-08-2025 05:05 AM - edited 08-08-2025 05:06 AM
Thank you to everyone's reply, I have been working on something else for the past day or so and didn't catch a change to further look into suggestions.
Yes and No, yes because it is isolated from other vlans and have it's own internet outbound gateway, no, because it reports data to certain host in other vlan and some hosts not in the IoT vlan needs to communicate with host inside the IoT vlan for device control, hanse the need for stateful acl.
@srimal99 wrote:route-map vpn-pbr1 permit 10 match ip address pbr-acl1. <----no reference to acl as per your post. Did you mean to match vpn-pbr-acl1 ?In addition to above mentioned post check the acl is correct ?
@MHM Cisco World wrote:
match ip address pbr-acl1<<- this name is wrongMHM
Thank you @MHM Cisco World, @srimal99 for pointing out the misspelled ACL, unfortunately after double checking each ACL names and rules. That did not solve the problem. The issue did change a bit but not solved yet, will mention below
@Joshqun Ismayilov wrote:
Hi@Karl3
Please change acl
Thanks !
I did thought of not using the tcp established to limit traffic and ditching reflective ACL, but there will be a mix of UDP and TCP traffic in and out of the vlan, so that won't do.
After fixing the misspelled ACL name and removing the log keyword so traffic won't all go through the CPU. Internet traffic from the IoT vlan get routed to the special gateway and LAN traffic are blocked from the IoT vlan. But when trying to ping from outside the IoT vlan, the icmp echo reply is blocked with maches for blocking LAN addresses counter rising
Extended IP access list CISCO-CWA-URL-REDIRECT-ACL
100 deny udp any any eq domain
101 deny tcp any any eq domain
102 deny udp any eq bootps any
103 deny udp any any eq bootpc
104 deny udp any eq bootpc any
105 permit tcp any any eq www
10 evaluate iot-1-in-refl
30 deny ip any 172.16.0.0 0.15.255.255 (182 matches)
Extended IP access list preauth_ipv4_acl (per-user)
10 permit udp any any eq domain
20 permit tcp any any eq domain
30 permit udp any eq bootps any
40 permit udp any any eq bootpc
50 permit udp any eq bootpc any
60 deny ip any any
40 permit ip any anyI also noticed the outbound traffic was not reflecting onto the iot-1-in-refl acl so changed the ACL to
ip access-list ext iot-1-out
no 10
10 permit ip any any log reflect iot-1-in-reflAnd everything worked, but now I am getting invalid ACL logs
Aug 8 11:32:29.598: %ACLMGR-3-INVALIDPARAM: Invalid ACL type 5 encountered
-Traceback= 7E98DCz 33BDF60z 3385AA0z 3B94FDCz 3B90CCCzIt is nice that things work, but not when there are warning about invalid configs.
After googling around, I came to the conclusion that this switch does not support reflective ACL on a hardware level, on software it would allow it, just doesn't work, by placing a log keyword on the outbound ACL, the ACL is being processed on the CPU instead of TCAM(which it can somewhat handle?), the ACL works as expected, in the expense of unknow outcome the more heavy traffic gets routed between the vlan.
I know, on paper this switch does not support advanced routing feature, but also a lot of what the doc says is not supported works, so ¯\_(ツ)_/¯
I would really like to know if anyone have encountered things like this in the past, any idea on what I should try next? Thank you to everyone for your input.
08-08-2025 05:12 AM
let me see ACL and route-map and policy config
MHM
08-08-2025 06:48 AM - edited 08-08-2025 06:56 AM
interface Vlan400
permit ip any any
permit ip any any
match ip address vpn-pbr-acl1
set ip next-hop 172.16.30.42The log keyword when applying the config is flipped with the reflect keyword, this is what's get outputted when doing sh run.
08-08-2025 07:04 AM - edited 08-08-2025 10:03 AM
MHM
08-08-2025 08:23 AM
Tried, now hosts outside the IoT vlan cannot ping hosts inside it. This is what shows when hosts outside the IoT vlan cannot ping hosts inside.
20 deny ip any 172.16.0.0 0.15.255.255 (4 matches)
50 evaluate iot-1-in-refl
permit icmp host 172.16.4.2 host 172.16.3.2 log (4 matches) (time left 299)
10 permit ip any any reflect iot-1-in-refl log (4 matches)
08-08-2025 10:32 AM - edited 08-08-2025 10:34 AM
permit ip any any
This config is correct' evaluation must be above deny
But I think you can not use icmp for check this type of ACL' icmp is stateless not statefull
You see automatic reflexive acl add it include icmp that wrong it need to be icmp reply.
One more note:- remove log from outbound access-list.
MHM
08-08-2025 11:40 AM - edited 08-08-2025 11:42 AM
@MHM Cisco World wrote:You see automatic reflexive acl add it include icmp that wrong it need to be icmp reply.
Reflexive IP access list iot-1-in-refl permit icmp host 172.16.4.2 host 172.16.3.2 log (4 matches) (time left 299)One more note:- remove log from outbound access-list.
I think it is just not displaying it properly, when I tried pinging back from 172.16.4.2 to 172.16.3.2, the icmp message is blocked. I forgot to mention, when an ICMP is packet is blocked, I get this message back
From 172.16.4.1 icmp_seq={} Packet filteredso I think the switch is not displaying the entries properly. I though this Packet filtered reply was normal so I didn't mention it before. The reason for the log is to make it work, without it, the ACL would not work. Without the log arg, pinging from outside the IoT vlan does not trigger the Packet filtered message, just no reply, also the matches on seq:20 in the iot-1-in ACL is going up, so I think the ICMP reply message is blocked by that rule. The seq:10 rule in the iot-1-out ACL is not matching anything.
For a sanity check, I created a web server on 2 host, one inside the vlan, one outside.
With the setup
permit ip any any reflect iot-1-in-reflThe host outside the IoT vlan times out when trying to access the web server
30 deny ip any 172.16.0.0 0.15.255.255 (42 matches)
10 permit ip any any reflect iot-1-in-reflWhen using
permit ip any any log reflect iot-1-in-reflThe host outside the IoT vlan, can access the web server inside the IoT vlan
30 deny ip any 172.16.0.0 0.15.255.255 (1 match)
permit tcp host 172.16.4.2 eq www host 172.16.3.2 eq 52616 log (13 matches) (time left 3)
10 permit ip any any reflect iot-1-in-refl log (8 matches)The reason, I think, in theory is that the ASIC that process ACLs cannot handle reflective-acl, but the CPU can, by having the log argument, the frame/packet is not directly handled by the ASICs, but is directed to the CPU for processing. This would explain why
%ACLMGR-3-INVALIDPARAM: Invalid ACL type 5 encounterednot appearing when, the log arg is not set. Apologies if I didn't mention that before. I think when the ACL filtering is done on the ASIC, the CPU is not involved, the ASIC not being able to handle reflective-acl would also explain why the frame/packet gets match both on both seq:5,20 on the first post
@Karl3 wrote:Extended IP access list iot-1-in 5 evaluate iot-1-in-refl 10 deny ip any 10.0.0.0 0.255.255.255 log 20 deny ip any 172.16.0.0 0.15.255.255 log (1041 matches) 30 deny ip any 192.168.0.0 0.0.255.255 log 40 permit ip any any Reflexive IP access list iot-1-in-refl permit icmp host 172.16.4.2 host 172.16.3.2 log (2037 matches) (time left 299) Extended IP access list iot-1-out 10 permit ip any any reflect iot-1-in-refl log (1019 matches) Extended IP access list vpn-pbr-acl1 10 deny ip any 10.0.0.0 0.255.255.255 20 deny ip any 172.16.0.0 0.15.255.255 30 deny ip any 192.168.0.0 0.0.255.255 40 permit ip any any
The ASIC treated the ACL like a normal ACL, incrementing the counter on the rule in iot-1-in-refl but also not knowing what to do with it and continue on matching seq:20.
Another thing that seems similar is when using object-group to define networks.
object-group network rfc1918
10.0.0.0 255.255.255.255
172.16.0.0 255.240.0.0
192.168.0.0 255.255.255.0
deny ip any object-group rfc1918
permit ip any any
permit ip any anyWith this applied, the both inbound and outbound acl gets ignored, with the PBR acl getting matched on permit ip any any when fetching the web server in the IoT vlan.
20 deny ip any object-group rfc1918
30 permit ip any any
10 deny ip any object-group rfc1918
20 permit ip any any (12 matches)I proceeded to add the log argument to the rules with object-group
deny ip any object-group rfc1918 log
permit ip any any
permit ip any anyThe accessing the web server in the IoT vlan did not work and same result as before, the host in the IoT vlan can access any ware without restriction as if the ACLs didn't exists.
20 deny ip any object-group rfc1918 log
30 permit ip any any (4 matches)
permit tcp host 172.16.4.2 eq www host 172.16.3.2 eq 34080 log (5 matches) (time left 288)
permit tcp host 172.16.4.2 eq www host 172.16.3.2 eq 47350 log (31 matches) (time left 290)
permit tcp host 172.16.4.2 eq www host 172.16.3.2 eq 52086 log (26 matches) (time left 143)
permit tcp host 172.16.4.2 eq www host 172.16.3.2 eq 34026 log (1 match) (time left 77)
10 permit ip any any reflect iot-1-in-refl log (24 matches)
10 deny ip any object-group rfc1918 log
20 permit ip any any (43 matches)PBR no longer routes internet traffic to the gateway, but that's some what to be expected, PBR need IP ACL, so I switch back to not using object-group
permit ip any any
permit ip any anyThe internet traffic from the IoT vlan gets routed to the gateway, but the 2 in/out ACL no longer have any effecy. None of the ACL hava any effects as if they don't even exists if object-group is defined.
So far the only config that works is
permit ip any any
permit ip any any
08-09-2025 04:54 AM
I check yesterday there is no need for log
But this point maybe answer here
Indeed log make acl handle by cpu not tcam (ASIC)
So it can that tcam have no space to have ACL of Policy route and reflexive and IN and OUT acl
What SW platform you use?
MHM
