03-20-2006 02:06 AM - edited 03-03-2019 12:06 PM
hello experts,
I have cisco 3550 layer 3 switch with vlan setup and 2 different ISP connected on it. The question is 1. how do i route the traffic from vlan-isp1 to go to the internet using isp1 and vlan-isp2 to isp2?
03-20-2006 02:11 AM
You need to set up the PBR on 3550.
http://www.cisco.com/univercd/cc/td/doc/product/lan/c3550/12225see/scg/swiprout.htm#wp1260543
HTH, Please rate if it does.
-amit singh
03-20-2006 04:45 AM
Thanks for the quick response, ill check those links 1st and keep you updated. :)
