Policy Based Routing
gses
Dear Friends.
We have more than 3 ISP Links.All the Links are terminated in the same router.
Is that Policy based routing will work More than 2 Links ?
Plese Help us.
Thanks and Regards
nagarajan.
Hello Nagarajan,
the amount of external links does not really matter, you just specify the traffic to ne matched and e.g. the egress interface or next hop.
Have a look at the example configuration below, it uses two different next hops, but you can add a third, fourth, etc...
Policy-based Routing
Differing Next Hops Example
http://www.cisco.com/en/US/products/ps6350/products_configuration_guide_chapter09186a00800c75d2.html#wp1001052
Does that answer your question ?
GP
Dear Sir,
Thank U very much. for your immediate reply.
can i get your maild id . i will send a mail of current configuration.and if you have a time please guide me about the THIRD ISP PBR CONFIG.
Thank u
regards
naga
HI Nagarajan,
Can you please post your config on the forum. It will be easy for anybody to post you the solution. As updated by last post number of ISPs terminating on your router does not matter. Just need to classify the traffic using ACLs and send it to exit interface or next hop.
Ankur
