Upgrading IOS on 7609
crumdub12
I am trying to upgrade IOS on Cisco 7609,
copied up to BOOTFLASH , set
BOOT SYSTEM FLASH / CONFIG-REG , RELOADED. The system seems to still use the golden image , when I first looked at DIR BOOTFLASH , there were no images , below is new BOOTFLASH , and SH VER , any ideas ??
Directory of bootflash:/
1 -rw- 11415856 Jul 26 2005 03:48:56 -08:00 wscmm-i6s-mz.124-1a.bin
65536000 bytes total (54120016 bytes free)
cnibhco100#sh ver
IOS (tm) s72033_rp Software (s72033_rp-PSV-M), Version 12.2(17d)SXB5,
RELEASE SO FTWARE (fc1) Technical Support:
http://www.cisco.com/techsupport Copyright (c) 1986-2004 by cisco
Systems, Inc. Compiled Fri 29-Oct-04 16:10 by pwade Image text-base:
0x40020FBC, data-base: 0x41CD0000
ROM: System Bootstrap, Version 12.2(17r)S2, RELEASE SOFTWARE (fc1)
BOOTLDR: s72033_rp Software (s72033_rp-PSV-M), Version 12.2(17d)SXB5,
cnibhco100 uptime is 7 minutes
Time since cnibhco100 switched to active is 6 minutes
System returned to ROM by unknown reload cause - suspect
boot_data[BOOT_COUNT] 0 x0, BOOT_COUNT 0, BOOTDATA 19 (SP by power-on)
System image file is "sup-bootflash:s72033-psv-mz.122-17d.SXB5.bin"
cisco CISCO7609 (R7000) processor (revision 1.1) with 983040K/65536K
bytes of me mory. Processor board ID FOX084101ET SR71000 CPU at 600Mhz,
Implementation 0x504, Rev 1.2, 512KB L2 Cache Last reset from power-on
X.25 software, Version 3.0.0. Bridging software. 1 Enhanced FlexWAN
controller (1 POS). 1 Virtual Ethernet/IEEE 802.3 interface(s) 74
Gigabit Ethernet/IEEE 802.3 interface(s) 1 Packet over SONET network
interface(s) 1917K bytes of non-volatile configuration memory. 8192K
bytes of packet buffer memory.
65536K bytes of Flash internal SIMM (Sector size 512K). Configuration
register is 0x2
amit-singh
Level 8
Level 8
Please paste the output of " dir sup-bootflash: ", Show boot.
regards,
-amit singh
Thanks for the quick response Amit,
cnibhco100#dir sup-bootflash:
Directory of sup-bootflash:/
1 -rw- 41026476 Dec 15 2004 03:15:04 -08:00 s72033-psv-mz.122-17d.SXB5
.bin
65536000 bytes total (24509396 bytes free)
cnibhco100#show boot
BOOT variable = sup-bootflash:,1
CONFIG_FILE variable does not exist
BOOTLDR variable =
Configuration register is 0x2
Standby is not present.
cnibhco100#
Do you want to upgrade the SUPengine or CMM module ????
The " wscmm-i6s-mz.124-1a.bin ". This file is for your communication module. This is a separate IOS for the CMM module. Please see the link below to upgrade the CMM module.
Your systems has SUP720/MSFC3 and its booting up with the correct image. If you want to upgrade the IOS on your sup engine please try to get an image for your sup engine.
Please see the link below for upgrading the SUP 720.
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat6000/122sx/ol_4164.htm
Please see the link to download the IOS for 7600 with Sup 720.
http://www.cisco.com/cgi-bin/Software/Iosplanner/Planner-tool/iosplanner.cgi?get_crypto=&data_from=&hardware_name=7600-SUP720%2FMSFC3&software_name=&release_name=&majorRel=12.2&state=:HW&type=
http://www.cisco.com/en/US/products/hw/switches/ps708/prod_release_note09186a008028f214.html#wp16934
HTH,
-amit singh
Amit,
Apologies about reply, was trying SUP Upgrade.
Got IOS Image s72033-pk9sv-mz.122-17d.SXB8.bin, but as it is 40 Meg , had to DELETE and SQUEEZE the sup-bootflash.
Am having a problem loading it.... , when COPY TFTP SUP-BOOTFLASH , it seems to stop at 33 Meg , and start over again at 0 , when it reaches 31 Meg on second load , it stops and tells me it is out of memory, do you have any ideas ???
42,007,568 s72033-pk9sv-mz.122-17d.SXB8.bin
%Error writing sup-bootflash:/s72033-pk9sv-mz.122-17d.SXB8.bin (No space left on
device)
No files in directory
65536001 bytes total (1 bytes free)
cnibhco100#squeeze sup-bootflash:
All deleted files will be removed. Continue? [confirm]
Squeeze operation may take a while. Continue? [confirm]
Squeeze of sup-bootflash complete
65536000 bytes total (65536000 bytes free)
