Policy based static Natting - HELP
carl_townshend
Hi All
We have a requirement wherby we have device which needs to be accessable from the outside, so we have done a 1 to 1 static nat from our dialler interface using port number, this works fine.
However the same router have a site to site vpn connected to our HQ, We need to be able to access this same device over the vpn tunnel. however it doesnt seem to work. When we remote the static translation, it then works.
Obviously we have a no nat configured for the siste to site tunnel, but we need it to be able to work over both ways.
Is this possible ?
Jon Marshall
You need to use a route map with your NAT.
See this thread for details -
https://supportforums.cisco.com/discussion/12544291/ipsec-ip-nat-inside-source-static
Jon
10 Replies 10
Hello
Not sure i understand this - isnt you Site-2 Site vpn connecting internally?
res
Paul
Kind Regards
Paul
Yes the site to site connects to us internally
however we have third party who also requires access to this device from the internet hence the static translation
Hello Carl
As you have stated you already have created the static translation- correct?
What is the need for another one - I must be missing something apologies!
res
Paul
Kind Regards
Paul
Basically, it works when coming from the internet, but if I try to access the inside up over a VPN tunnel, it does not work, it's almost like the return traffic is getting natted
any ideas?
Hello
are you trying via the external ip or internal
also what's your dns - do you have A records
Relating to the internal and external  addressing ?
res
paul
Kind Regards
Paul
ok
basically we need to access a device on the LAN behind the router, from both the internet using a static 1 to 1 NAT as below
ip nat inside source static tcp 172.16.1.1 30000 interface Dialer1 30000
This router also has a VPN to our HQ using a crypto map,
we need to be able to access the 172.16.1.1 address over the vpn also, but it fails.
If we take the ip nat static translation off, it works fine over the vpn.
how would we fix this so we can connect using both ways ?
I have already answered your question above.
See the link I provided.
Jon
Are you using GRE tunnel for VPN or you are using crypto map on the dialer interface?
If your are using Tunnel interface, you do not need to be concern about NAT because you do not have IP NAT outside on the interface(probably), but if you use crypto map, you need to do translation based on policy. It can be done by route-map. Please explain more about your configuration.
Masoud
All sorted, thankyou, used a route map with the deny statement.
worked a treat
mant thanks for your help
Jon Marshall
Jon
