Policy-map is wasting my BANDWIDTH
hello , i have asr1006 and i used it for PPPOE server for user
 For example
500 users is connected to router via PPPOE
and they have all of them downloading file
and i config when user connected he get Policy-map
Policy Map user
  Class class-default
   police cir 100000 bc 3125
     conform-action transmit
      exceed-action drop
so if all of them downloading in same time
they traffic must be 500Mbps ,
but i see they input interface is have 700Mbps traffic And PRTG of my ISP Is read 700Mbps
 why ? and all of users  has policy-map and they traffic speed is limited to 1Mbps?
maybe they have dropped and the Send request to internet and internet replay to them so the traffic is has more of 500Mbps
how to limit user and when he have drop he must can’t send more upload packet
* i use radus to set policy name when user connect
* ii need to limit user a thought not just out or in
so if he have downloading 1mbps he can’t send more request to internet and that will save my traffic
12 Replies 12
how do you have this set up, is this a test lab ? How do you simulate 500 users downloading files at exactly the same time ?
hello we are ISP , now i have my Router with 1000 real user is online ..
But i give you small example to understand my issue ,
another example
1000 real user is online , and all of them has policy-map 1Mbps
but i can see they traffic more of 800Mbps or 900Mbps , and is imposable all of them downloading  download same ,
what i mean ,i need to policy-map user for thought traffic not two policy - upload/Download
My analysis is all user have 1Mbps Download limited , but when user downloading and use all his traffic (1m) he have another policy-map for upload so he can send more request for example (browsing) , his request will get replay from internet  to my router , and my router will drop this packer because user have use all of 1mbps , but the packet already delivery to my router and this wasting my BANDWIDTH
Joseph W. Doherty
Where are you measuring the aggregate bandwidth usage?
If, for example, as an ingress policy on an interface, ingress could exceed the policing limits, as the traffic enters the interfaces, but shouldn't exceed the aggregate as forwarded to the egress interface(s).
If, the other hand, you have this as an egress policy, on an interface, then I would expect that interface not to exceed the aggregate unless there's other egress bandwidth not subject to the policy.
Hello, thanks for reply
let me give me your details,
my router has two interface
ten 0/0/0 is connect with my ISP
Ten 0/1/0 is has vlans with pppoe to my user's
so interface ten 0/0/0 is input my service
all user's in Ten 0/1/0 has limited with 1Mbps policy-map
but in peak-time traffic, for 500 user's has traffic more of 700Mbps
interface ten 0/0/0 input: 700Mbps
interface Ten0 / 1/0 Ouput : 700Mbps
how that ? and all user's is have limit traffic with 1Mbps
so if they are all of them downloading files in same time (and that's imposable) the Will not exceed 500Mbps , but the real traffic from my ISP is 700Mbps
Again, what interface(s) and what direction(s) (i.e. in or out or both) is policy assigned?
Policy Map user
  Class class-default
      exceed-action drop
bba-group pppoe PPPOE-DEFAULT
 virtual-template 101
 sessions per-vc limit 1
 sessions per-mac limit 1
 sessions per-vlan limit 10000 inner 10000
 sessions auto cleanup
interface Virtual-Template100
 description POOL-QINQ
 mtu 1492
 ip unnumbered Loopback0
 ip nat inside
 ip tcp adjust-mss 1440
 keepalive 15
 ppp mtu adaptive
 ppp authentication chap ms-chap ms-chap-v2 eap pap
 ppp ipcp dns 8.8.8.8 8.8.4.4
 ppp timeout retry 9
 ppp timeout authentication 20
 ppp timeout idle 172800 either
end
interface TenGigabitEthernet0/1/0
 description ISP-IN
 ip address 94.X.X.X 255.255.255.128
 ip nat outside
end
interface TenGigabitEthernet0/1/0.20
 description USER
 encapsulation dot1Q 913 second-dot1q any
 pppoe enable group PPPOE-QINQ
end
Type: PPPoE, UID: 9317, State: authen, Identity: adminsaad@o2
IPv4 Address: 10.121.20.139
Session Up-time: 2d20h   , Last Changed: 2d20h
Interface: Virtual-Access1.7748
Switch-ID: 34067519
Policy information:
  Context 7FE3FF8300D8: Handle 90020080
  AAA_id 0003F65B: Flow_handle 0
  Authentication status: authen
Classifiers:
Class-id    Dir   Packets    Bytes                  Pri.  Definition
0           In    71395279   7947823856             0    Match Any
1           Out   126300009  154445884464           0    Match Any
Features:
QoS Policy Map:
Class-id    Dir   Policy Name   Source
0           Out          user            Peruser
IP Config:
M=Mandatory, T=Tag, Mp=Mandatory pool
Flags  Peer IP Address                  Pool Name             Interface
       0.0.0.0                          subscriber2           [None]
       ::                               [None]                [None]
Absolute Timeout:
Class-id   Timeout Value    Time Remaining       Source
0          2741505          4w0d                 Peruser
Idle Timeout:
Class-id   Dir  Timeout value   Idle-Time            Source
0          In   172800          00:00:02             Virtual-Template100
1          Out  172800          00:00:02             Virtual-Template100
Configuration Sources:
Type  Active Time  AAA Service ID  Name
USR   2d20h        -               Peruser
INT   2d20h        -               Virtual-Template100
Switch-ID: 34067519
Policy information:
Classifiers:
Features:
QoS Policy Map:
0           Out          user            Peruser
IP Config:
       ::                               [None]                [None]
Absolute Timeout:
Idle Timeout:
USR   2d20h        -               Peruser
  Service-policy output: ussr
    Class-map: class-default (match-any)
      14559817 packets, 2670943646 bytes
      30 second offered rate 18000 bps, drop rate 0000 bps
      Match: any
      police:
          cir 10000000 bps, bc 2500000 bytes
        conformed 14515097 packets, 2569676143 bytes; actions:
          transmit
        exceeded 75791 packets, 105166670 bytes; actions:
          drop
        conformed 18000 bps, exceeded 0000 bps
looking at your output:
Match: any
police:
transmit
drop
--> cir 10000000 bps equals 10Mbps, not 1Mbps
hello , thanks for replay,  yes in config i was open 10Mbps in night time
but i mean in peak-time traffic  i give user1' 1Mpbs
Policy Map user
  Class class-default
      exceed-action drop
but the are using  more than expected traffic
Policy Map user
Class class-default
exceed-action drop
I think the value is in bits per second, so you need to add a '0' for one Mbit. 100000 means 0.1 Mbit.
hello ,thanks for reply
don't care about some text error
i mean when use limit
Policy Map user
Class class-default
police cir 1000000 bc 3125
exceed-action drop
for 500 user'
the in interface traffic is going to more of 500Mbps (600 or 700 )
so how that's and all user's has limit traffic for 1Mbps
any idea how to limit use for throughput not just upload or download
so if he download file with speed 1Mbps
he can't upload file in  same time
