Policy-Map - Offered rate to high
Heinz Kern
I´m facing a confuse problem. maybe the solution is simple but i can´t find it.
the show policy map shows an offered rate far above the target shape rate
show policy-map interface tunnel 204
Tunnel204
  Service-policy output: BA-DBNA-BRANCH-OUT-2M
    Class-map: class-default (match-any)
      20511 packets, 782918464 bytes
      30 second offered rate 17882000 bps, drop rate 0 bps
      Match: any
      Queueing
      queue limit 64 packets
      (queue depth/total drops/no-buffer drops) 0/0/0
      (pkts output/bytes output) 20515/7366846
      shape (average) cir 1940000, bc 19400, be 0
      target shape rate 1940000
      Service-policy : BA-DBNA-BRANCH-OUT
        queue stats for all priority classes:
          (pkts output/bytes output) 17550/6619020
        Class-map: BA-DBNA-VOIP (match-any)
          17550 packets, 770242200 bytes
          30 second offered rate 17630000 bps, drop rate 0 bps
          Match: mpls experimental topmost 5
            17484 packets, 770240136 bytes
            30 second rate 17630000 bps
          Match: ip dscp ef (46)
            66 packets, 2064 bytes
            30 second rate 0 bps
          Priority: 60% (1164 kbps), burst bytes 29100, b/w exceed drops: 0
the tunnel-interface as well as the physical interface show the correct statistics when doing a show interface
show interfaces gigabitEthernet 0/1
GigabitEthernet0/1 is up, line protocol is up
  Hardware is CN Gigabit Ethernet, address is e05f.b903.30f1 (bia e05f.b903.30f1)
  Description: 01-00-246387-1011 - 2M
  MTU 1578 bytes, BW 100000 Kbit/sec, DLY 100 usec,
  Encapsulation 802.1Q Virtual LAN, Vlan ID  1., loopback not set
  Keepalive set (10 sec)
  Full Duplex, 100Mbps, media type is RJ45
  output flow-control is unsupported, input flow-control is unsupported
  Last input 00:00:00, output 00:00:00, output hang never
  Queueing strategy: Class-based queueing
  Output queue: 0/1000/0 (size/max total/drops)
  30 second input rate 170000 bits/sec, 62 packets/sec
  30 second output rate 162000 bits/sec, 55 packets/sec
     234536 packets input, 78663340 bytes, 0 no buffer
     Received 22658 broadcasts (0 IP multicasts)
     0 watchdog, 18509 multicast, 0 pause input
     212201 packets output, 74583997 bytes, 0 underruns
     0 output errors, 0 collisions, 2 interface resets
     7440 unknown protocol drops
     1 lost carrier, 0 no carrier, 0 pause output
show interfaces tunnel 204
Tunnel204 is up, line protocol is up
  Hardware is Tunnel
  Description: to AT-DBN-T2-R1 Tunnel2042499 primary
  Internet address is 12.221.144.206/30
  MTU 17916 bytes, BW 1940 Kbit/sec, DLY 50000 usec,
     reliability 255/255, txload 20/255, rxload 29/255
  Encapsulation TUNNEL, loopback not set
  Keepalive not set
  Tunnel source 12.121.144.206 (GigabitEthernet0/1.2499), destination 12.121.144.205
   Tunnel Subblocks:
      src-track:
         Tunnel204 source tracking subblock associated with GigabitEthernet0/1.2499
          Set of tunnels with source GigabitEthernet0/1.2499, 1 member (includes iterators), on interface <OK>
  Tunnel protocol/transport GRE/IP
    Key disabled, sequencing disabled
    Checksumming of packets disabled
  Tunnel TTL 255, Fast tunneling enabled
  Tunnel transport MTU 1554 bytes
  Tunnel transmit bandwidth 8000 (kbps)
  Tunnel receive bandwidth 8000 (kbps)
  Tunnel protection via IPSec (profile "DBNA-KEYRING")
  Last input 00:00:00, output never, output hang never
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 1
  Queueing strategy: fifo (QOS pre-classification)
  Output queue: 0/0 (size/max)
  30 second input rate 228000 bits/sec, 109 packets/sec
  30 second output rate 156000 bits/sec, 58 packets/sec
     232495 packets input, 59455529 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicasts)
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     223872 packets output, 74714660 bytes, 0 underruns
     89 unknown protocol drops
does anybody have an idea? platform is 2900
thx
6 Replies 6
Heinz Kern
there is a far more easy setup with the same problem:
Tunnel204
      5983 packets, 149595053 bytes
      30 second offered rate 15750000 bps, drop rate 0 bps
      Match: any
      Queueing
      (pkts output/bytes output) 5905/1905042
config:
policy-map BA-DBNA-BRANCH-OUT-2M
class class-default
  shape average 1940000 19400 0
IMHO,offered rate is the rate the matching packets are received.
So it's not the rate the route would be "offering" to the packet flows, it's just a confusing Cisco term.
See http://www.cisco.com/en/US/customer/docs/ios/12_2/qos/command/reference/qrfcmd10.html#wp1049822
Best regards,
Milan
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
If I'm reading your stats correctly, looks like the offered rate has slipped a decimal for is display, i.e. 10x too much.
If you have support, bring it to TAC or try a later IOS release, if available.
thanks for the answers
@ milan: i don´t think that you are correct. a show int tunnel shows the true bandwidth and it is suitable (approx 120kbps). a "sho policy-map int tunnel " shows several Mbit/s. i don´t see a reasonable answer for that
@ joseph: i already opened a case. but i wanted  to prevent that
Disclaimer
Posting
Why prevent opening a TAC case, that's why we pay for support?
I suspect its a cosmetic bug.  However if you're impatient with TAC, besides trying a newer release, you might also try older too, as bugs are sometimes introduced.
Offered rate should be the "ingress" rate to the CBWFQ class.  The aggregate of all class offered rates, less their drop rates, should be the reflected on the interface's rate (of course, ingress or egress depending on input or output policy - also accounting for multiple policies on "interfaces" like subinterfaces or tunnels).
I believe I've noticed that the rates are not always exactly "sync'ed", but they shouldn't be as far off as your stats show.
BTW, what exact platform and IOS are you seeing this on?
tac-case always takes such a lot of time. perhaps routing is a bit better...but wlan is really a mess
platform is 2900 with 15.1.4
