Policy-Map / QoS
nelsonm
I have an issue at a remote site that when I run backups (on 1 server) that it brings the WAN to a grinding halt. I thought I would use QoS/Policy map to guarantee bandwidth for Citrix and printing but does not seem to be working. It appears that it's not interpreting the protocols citrix and printer. Just wanting a second pair eyes to see if maybe I'm missing something .
class-map match-all citrix
match protocol citrix
match protocol printer
policy-map Citrix-QoS
class citrix
priority percent 40
class class-default
fair-queue
interface Multilink1
description PPPML for FTR
ip address 172.16.*.* 255.255.255.252
ip nbar protocol-discovery
ip route-cache flow
no cdp enable
ppp multilink
ppp multilink group 1
service-policy output Citrix-QoS
interface FastEthernet0/0
no ip address
ip helper-address 10.1.1.104
ip route-cache flow
speed auto
full-duplex
interface FastEthernet0/0.10
encapsulation dot1Q 10
ip address 10.*.*.1 255.255.255.0
interface FastEthernet0/0.30
encapsulation dot1Q 30
ip access-group 130 in
interface Serial0/0
no ip address
encapsulation ppp
no fair-queue
ppp multilink
interface Serial1/0
no ip address
encapsulation ppp
no fair-queue
no cdp enable
ppp multilink
router eigrp 333
network 10.0.0.0
network 172.16.0.0
no auto-summary
ip forward-protocol nd
ip flow-export source Multilink1
ip flow-export version 5
ip flow-export destination 10.1.1.124 9996
FTR-PTP-1760#sho policy-map interface
Multilink1
Service-policy output: Citrix-QoS
Class-map: citrix (match-all)
0 packets, 0 bytes
5 minute offered rate 0 bps, drop rate 0 bps
Match: protocol citrix
Match: protocol printer
Queueing
Strict Priority
Output Queue: Conversation 264
Bandwidth 40 (%)
Bandwidth 1235 (kbps) Burst 30875 (Bytes)
(pkts matched/bytes matched) 0/0
(total drops/bytes drops) 0/0
Class-map: class-default (match-any)
2764051 packets, 220776934 bytes
5 minute offered rate 99000 bps, drop rate 2000 bps
Match: any
Queueing
Flow Based Fair Queueing
Maximum Number of Hashed Queues 256
(total queued/total drops/no-buffer drops) 0/152088/0
FTR-PTP-1760#
Joseph W. Doherty
Instead of:
Try:
class-map match-any citrix
5 Replies 5
Joseph W. Doherty
Instead of:
Try:
That fixed it! Awesome! Thank so much!
Is the NBAR making it possible to classify the protocols like this?
I didn't see it defined any where else:
Richard
"Is the NBAR making it possible to classify the protocols like this"
Yes it is. The "match protocol" within a class-map is what triggers use of NBAR for classifying traffic.
Jon
Thanks Jon,
Are there guideline documents on how to use NBAR and QoS like this?
We have NBAR configured on our router interfaces, but it is not in use in QoS policies like this.
We have MARS monitoring the network, does it use NBAR?
