Policy Route Map
ahpark78
Anyone knows what is the policy route map below means..I am confused..
Thanks in advanced!
interface FastEthernet0/0.1
encapsulation dot1Q 1 native
ip address 122.1.x.x.255.255.0
no ip redirects
ip accounting access-violations
ip policy route-map ID
ip access-list extended ID
permit ip host 122.1.8.3 any
6 Replies 6
mohammedmahmoud
Level 11
Level 11
Can you please post the route-map named "ID".
BR,
Mohammed Mahmoud.
Hi Mahmoud,
As below:
route-map ID permit 10
match ip address I/D
and sorry...ip access-list extended I/D should be the right one..
Hi Cindy,
Since the route-map doesn't has any set entry, thus it won't do anything, normal routing using the routing table shall be done.
HTH,
Mohammed Mahmoud.
H Mahmoud,
How can we know there there is no set entry and also what is the number of 10 represents?
DO you have any example on this route-map ?
Thanks in advanced again!
Hi Cindy
If what you posted was the full output of the route-map then we know there is no set part to it. This basically means you can match as much as you like but nothing will be done.
You only have one entry but if you wanted another entry to your route-map you could another number eg.
route-map ID 20
etc...
The packet will be checked against each entry in your route-map until it finds a match.
Jon
Hi Cindy,
I guess Jon has given a nice explaination, here you are some details about PBR and using route-maps:
Policy-Based Routing
http://www.cisco.com/warp/public/732/Tech/plicy_wp.htm
Configuring Policy-Based Routing
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122cgcr/fqos_c/fqcprt1/qcfpbr.htm
HTH,
Mohammed Mahmoud.
