policy routing - non adjacent
I read that set ip next hop address will only work if the next hop is directly connected/adjacent. Is there any work around for non adjacent next hops? Thanks in advance.
pkhatri
Level 11
Level 11
There certainly is a work around. Use the 'set ip next-hop recursive ' and the router will determine the actual next-hop by doing a recursive lookup for the specified IP.
Hope that helps - pls rate the post if it does.
Paresh
