Policy routing problem
rawatmohinder
Q:- If you have configured route redistribution between separate routing domains and have included route filters to prevent route feedback, which command would you use on a boundary router to verify that redistribution is working correctly?
A. show ip protocols
B. trace
C. show ip access-lists
D. ping
Q:- On Cisco routers, fast switching of policy-based routing _____.
A. is not supported
B. requires the ip fast policy interface configuration command
C. requires the ip fast policy router configuration command
D. requires the ip route-cache policy router configuration command
E. requires the ip route-cache policy interface configuration command
Mahi
Patrick Laidlaw
Level 4
Level 4
Question 1 is "show ip protocols"
Question 2 I've got to look up but for some reason i want to say the answer is (A)
Can someone give a crack at question 2 and give us a firm answer.
Patrick
rawatmohinder
For first question A is not a correct answer... But i don,t know the correct one..
Kindly help me out...
Mahi
Mahi,
I believe the answer should be B. The reason is that a traceroute will show you the presence of a routing loop, which is a frequent result of route feedback when redistributing protocols.
Hope that helps - pls do remember to rate posts that help.
Paresh
