10-02-2024 01:05 PM
Hi Dears If i want policy-map work in vlan on port-channel on must be add for example
port-channel 1
load-balance vlan
if add this router tx Traffic on one physical interface on port-channel
And inteface so congestion If disable load-balance vlan disable on port-channel 2
traffic is ok but policy-map suspend on vlans
How Solve this ??? Please Help me
10-02-2024 02:14 PM
Hello admin@atrinnet.net ,
if the platform is an ASR1000:
break the port-channel and create two ECMP L3 paths eventually use VLAN based subinterfaces on each of them and try to apply PBR on them
CEF will provide load balancing flow based
Hope to help
Giuseppe
10-03-2024 12:35 AM
Thanks For attention I Added Sub-Interface on port-channel
for example port-channle 1.2
encapsulation dot1q 2
and load-balance flow base
and apply
when show policy-map interface-port-channel 1.2
show me suspeneded
10-03-2024 12:46 PM
there is no parity feature between port-channels and Equal Cost multi path on routers not only for ASR1000.
this is the reason why I have suggested to unbundle the links and make them indipendent L3 for ECMP at this point CEF performs for your flow based load balancing and you get one or two points where you can apply PBR on inbound user traffic
Hope to help
Giuseppe
