ā02-15-2017 07:03 AM - last edited on ā03-25-2019 03:48 PM by ciscomoderator
Hi Friends,
I need your support that can we configure the below task
1) Port channel configuration in Cisco ASR1001-X router by using two port in between both chassis( ASR 1000x Router).
2) Sub port-channel configuration in same router .
Please share any link if you have.
As i have to implement the both task.
Ganesh
Solved! Go to Solution.
ā02-15-2017 11:26 PM
Configure the 2960 to use LACP. Yes, it will work.
ā02-15-2017 10:02 PM
interface GigabitEthernet1/0/0
channel-group 1
interface GigabitEthernet1/0/1
channel-group 1
interface Port-channel1.10
encapsulation dot1Q 10
interface Port-channel1.20
encapsulation dot1Q 20
ā02-15-2017 11:12 PM
Thanks for prompt response Philip D'Ath !
i got config shared by you , but i am not sure it will be work on ASR1000X or not as i have not reconfigured these devices in port-channel & port-channel sub-interface in ASR router ,so am not sure.
ASR1000XRouter ====O====Cisco2960Switch
I Just want to know it will work as my all link will be terminated on Cisco 2960 switch and ASR router will be connect with Cisco 2960 with bundling two up link port and all WAN L3 interface will be configured on Router's port-channel (Sub interface).
So it will work or not ?
Ganesh
ā02-27-2017 01:08 AM
