Port Channel issue between Two Point-to-Point WAN Links
Ajay Koorata
I have two office locations which are approximately a kilometer apart and is connected by two Point-to-Point WAN links provided by two different ISP's.
Each links is of 45 Mbps. I am trying to bundle both of these links into a Ether-channel, however, I am facing some challenges.
I have tested both links individually and its working fine. Even i was able to bundle it without using negotiation protocols-PAgP or LACP (using ON). But the problem is if any one of the link or interface goes down in either end, I am losing the entire connectivity between sites. Also what i have observed is that if i shutdown either ISP_1 or ISP_2 interfaces on both ends (when it is bundled) then there is no issue.
So  I am not able to achieve the actual goal of having an Ether-channel.
Below is the current Configuration which is working fine at the moment.
Site-A
3850-SW1#sh run int gi 1/0/9
Building configuration...
Current configuration : 152 bytes
interface GigabitEthernet1/0/9
 description ***ISP_1***
 switchport mode trunk
 speed 100
 duplex full
 channel-group 5 mode on
end
3850-SW1#sh run int gi 1/0/10
Current configuration : 151 bytes
interface GigabitEthernet1/0/10
 description ***ISP_2***
 speed 100
 duplex full
end
3850-SW1#sh run int po5
Current configuration : 112 bytes
interface Port-channel5
 description ***To_3850-SW2***
 speed 100
 duplex full
end
3850-SW1#sh etherchannel 5 su
Flags:  D - down        P - bundled in port-channel
        I - stand-alone s - suspended
        H - Hot-standby (LACP only)
        R - Layer3      S - Layer2
        U - in use      f - failed to allocate aggregator
        M - not in use, minimum links not met
        u - unsuitable for bundling
        w - waiting to be aggregated
        d - default port
Number of channel-groups in use: 5
Number of aggregators:           5
Group  Port-channel  Protocol    Ports
5      Po5(SU)          -        Gi1/0/9(P)  Gi1/0/10(P)
3850-SW1#sh int gi 1/0/9
GigabitEthernet1/0/9 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is 189c.5d17.8989 (bia 189c.5d17.8989)
  Description: ***ISP_1***
  MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
     reliability 255/255, txload 7/255, rxload 95/255
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, media type is 10/100/1000BaseTX
  input flow-control is off, output flow-control is unsupported
  Last input 22:20:54, output never, output hang never
  Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 37395000 bits/sec, 4653 packets/sec
  5 minute output rate 2787000 bits/sec, 1861 packets/sec
     1193866499 packets input, 1240289447 bytes, 0 no buffer
     Received 529960 broadcasts (364319 multicasts)
     3 input errors, 2 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog, 364319 multicast, 9302883 pause input
     1240533949 packets output, 4274348333 bytes, 0 underruns
     0 output errors, 0 collisions, 13 interface resets
     0 unknown protocol drops
     0 lost carrier, 0 no carrier, 0 pause output
3850-SW1#sh int gi 1/0/10
GigabitEthernet1/0/10 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is 189c.5d17.898a (bia 189c.5d17.898a)
  Description: ***ISP_2***
     reliability 255/255, txload 100/255, rxload 12/255
  Last input 00:00:14, output never, output hang never
  5 minute input rate 4865000 bits/sec, 1041 packets/sec
  5 minute output rate 39453000 bits/sec, 3924 packets/sec
     625518180 packets input, 3078590463 bytes, 0 no buffer
     Received 4726585 broadcasts (3860846 multicasts)
     0 watchdog, 3860846 multicast, 0 pause input
     839274849 packets output, 72907943 bytes, 0 underruns
     0 output errors, 0 collisions, 7 interface resets
3850-SW1#sh int po5
Port-channel5 is up, line protocol is up (connected)
  Hardware is EtherChannel, address is 189c.5d17.8989 (bia 189c.5d17.8989)
  Description: ***To_3850-SW2***
  MTU 1500 bytes, BW 200000 Kbit/sec, DLY 100 usec,
     reliability 255/255, txload 53/255, rxload 52/255
  Full-duplex, 100Mb/s, link type is auto, media type is
  Members in this channel: Gi1/0/9 Gi1/0/10
  Last input 00:00:00, output never, output hang never
  5 minute input rate 41503000 bits/sec, 5634 packets/sec
  5 minute output rate 42280000 bits/sec, 5761 packets/sec
     1819416500 packets input, 37549348 bytes, 0 no buffer
     Received 5256594 broadcasts (4225195 multicasts)
     0 watchdog, 4225195 multicast, 9302883 pause input
     2079838549 packets output, 82510093 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
Site-B
3850-SW2#sh run int gi 1/0/24
Current configuration : 157 bytes
interface GigabitEthernet1/0/24
 speed 100
 duplex full
end
3850-SW2#sh run int gi 2/0/24
Current configuration : 155 bytes
interface GigabitEthernet2/0/24
 speed 100
 duplex full
end
3850-SW2#sh run int po5
Current configuration : 116 bytes
 description ***TO_3850-SW1***
 speed 100
 duplex full
end
3850-SW2#sh etherchannel 5 su
        d - default port
Number of channel-groups in use: 1
Number of aggregators:           1
5      Po5(SU)          -        Gi1/0/24(P) Gi2/0/24(P)
3850-SW2#sh int gi 1/0/24
GigabitEthernet1/0/24 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is 8480.2d94.5b98 (bia 8480.2d94.5b98)
     reliability 255/255, txload 122/255, rxload 7/255
  Last input 00:00:05, output never, output hang never
  Last clearing of "show interface" counters 2w5d
  5 minute input rate 2758000 bits/sec, 2033 packets/sec
  5 minute output rate 47996000 bits/sec, 5577 packets/sec
     1189754195 packets input, 4252242003 bytes, 0 no buffer
     Received 4228735 broadcasts (3889387 multicasts)
     0 watchdog, 3889387 multicast, 0 pause input
     1175349750 packets output, 1127653607 bytes, 0 underruns
     0 output errors, 0 collisions, 3 interface resets
     3 unknown protocol drops
3850-SW2#sh int gi 2/0/24
GigabitEthernet2/0/24 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is 6899.cdf7.6918 (bia 6899.cdf7.6918)
     reliability 255/255, txload 13/255, rxload 104/255
  Last input 00:00:02, output never, output hang never
  5 minute input rate 40999000 bits/sec, 4105 packets/sec
  5 minute output rate 5212000 bits/sec, 1095 packets/sec
     836857372 packets input, 1648069837 bytes, 0 no buffer
     Received 42717801 broadcasts (35073673 multicasts)
     0 watchdog, 35073673 multicast, 0 pause input
     625207137 packets output, 2864794486 bytes, 0 underruns
     0 output errors, 0 collisions, 6 interface resets
3850-SW2#sh int po5
  Hardware is EtherChannel, address is 8480.2d94.5b98 (bia 8480.2d94.5b98)
  Description: ***TO_3850-SW1***
     reliability 255/255, txload 67/255, rxload 55/255
  Members in this channel: Gi1/0/24 Gi2/0/24
  5 minute input rate 43725000 bits/sec, 6139 packets/sec
  5 minute output rate 53294000 bits/sec, 6672 packets/sec
     2072525594 packets input, 3576579744 bytes, 0 no buffer
     Received 46967137 broadcasts (38981141 multicasts)
     0 watchdog, 38981141 multicast, 0 pause input
     1839423586 packets output, 659594591 bytes, 0 underruns
     150224 output errors, 3467 collisions, 1 interface resets
     0 babbles, 1046 late collision, 0 deferred
When i used LACP  / PAgP , i was not able to bundle both interfaces and when i tried to add the second link using "channel-group" command I got below error which i received on both ends and lost connectivity.
*May 26 06:54:31.171: %SW_MATM-4-MACFLAP_NOTIF: Host 0060.2d01.342f in vlan 1 is flapping between port Po5 and port Gi1/0/24 (3850-SW2-2)
*May 26 06:54:33.893: %SW_MATM-4-MACFLAP_NOTIF: Host d067.e5ea.9ef1 in vlan 1 is flapping between port Gi1/0/24 and port Po5
*May 26 06:54:34.434: %SW_MATM-4-MACFLAP_NOTIF: Host 5ca4.8a10.54b0 in vlan 1 is flapping between port Gi1/0/24 and port Po5
*May 26 06:54:33.937: %SW_MATM-4-MACFLAP_NOTIF: Host d067.e5ea.9ef1 in vlan 1 is flapping between port Gi1/0/24 and port Po5 (3850-SW2-2)
*May 26 06:54:34.444: %SW_MATM-4-MACFLAP_NOTIF: Host 5ca4.8a10.54b0 in vlan 1 is flapping between port Gi1/0/24 and port Po5 (3850-SW2-2)
*May 26 06:54:35.192: %SW_MATM-4-MACFLAP_NOTIF: Host c434.6b65.bd80 in vlan 1 is flapping between port Gi1/0/24 and port Po5
Any suggestion / guidelines are most welcome :)
Thanks in Advance..
Hello.
You either need to use LACP or use dynamic routing to trigger switchover on link failure.
To run LACP, you need to confirm with  your ISPs that they are allowing LACP packets on the wire.
To run dynamic routing - you may use any ECMP supporting protocols (like EIGRP, OSPF or whatever).
PS: to configure LACP - shutdown both interfaces, do configuration on BOTH sides and only after - unshut.
Thank you for the suggestions.. Meanwhile I'm exploring the options of dynamic routing with load balancing on both links
