Port F0/0 protocol down on Router 1841?
rechard_hk
Dear All,
I have issue on Cisco Router 1841 on port F0/0 is protocol down
Router#sh ip int br
Interface                  IP-Address      OK? Method Status                Protocol
FastEthernet0/0            unassigned      YES unset  up                    down
FastEthernet0/1            unassigned      YES unset  up                    up
And i try to no shut on port F0/0 but it still donw and  FDX,100 and Link don't have light.
i trty to change cable stragth and cross already but it still down, How can we know this port spoil?
Best Regards,
Rechard
9 Replies 9
Sandeep Choudhary
Hi Rechard,
Check
1) Cabling - use a cable that is known to be working
2) Duplex - either Auto/Auto on both sides or hard coded for speed and duplex
3) IOS - are you using a stable IOS?
4) Change the device it is connected to on the other end to see if there is any change
Specially configure these :
Duplex full
Speed 100
Duplex half
Speed 10
Duplex half
Speed 100
Double full
Speed 10
Try this able Combination and let me know.
Please rate, if it helps.
Dear Sir,
I tasted already but it still problem:
    The cable is working, if i connect this to port 0/1 is working.
    i try to change Auto/Auto or halft , speed 100 or speed 10 but it still down.
  This IOS that i use :  advipservicesk9-mz.124-9.T3
  I connected from My PC to Cisco Router .
Best Regards,
Rehcard
can you put your config from the router of the interface fa0/0 and the config from the other side where its is connected???
may be its a problem of trunking protocol.
REgards
Dear Sir,
This config that i done :
interface FastEthernet0/0
ip address 192.168.7.4 255.255.255.0
speed 100
full-duplex
Router#sh ip int br
FastEthernet0/0            192.168.7.4     YES manual up                    down
FastEthernet0/1            unassigned      YES NVRAM  up                    down
Router#
Now port F0/0 connecting to other devide.
it still down, how can we know this port spoil or problem? i think may be it hardware (port f0/0) but i dont reference for this port spoil or not....
Best Regards,
Rechard
can you give me the out put of this coomand on router: sh interface fa0/0
and other output from the other device where this interface connected:sh int _
Dear Sir,
Router#sh int f0/0
FastEthernet0/0 is up, line protocol is down
  Hardware is Gt96k FE, address is 64a0.e7e3.a38e (bia 64a0.e7e3.a38e)
  Internet address is 192.168.7.4/24
  MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, 100BaseTX/FX
  Last input never, output never, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     0 packets input, 0 bytes
     Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
     0 watchdog
     127 packets output, 8547 bytes, 0 underruns
     0 output errors, 0 collisions, 2 interface resets
     0 lost carrier, 0 no carrier
where this port connected -....to .....-------------------------> pc
                                                    ..........................> switch ?
Dear Sir,
I test only one port, i mean port f0/0 connect to PC, and also i connect port f0/0 to switch ( normal switch and not cisco)
and it still not work.
Best Regards,
Rechard
Hi ,
Just try
1. use  new crossover cable to connect to pc or switch.
2. if you are conneting with switch then please check the port setting on switch: should be Full-duplex, 100Mb/s.
3. if you are connecting with a pc then please go and check the NIC setting:
NIC SETTING. my computer properties>hardware>device manager>network adaptor properties>link speed duplex mode should be full and speed 100Mbs.
rate it if it helps.
